03-08-2013
Re: mainsail roach and size of genny
Do you have sacrificial plastic strips sewn to the aft end of the batten pockets.
I do not. The sailmaker at Evolution did not recommend it and I did not think to ask. I did ask if there would be a lot of chaff and he explained that when tacking, the sail slacks and there isn't that much chaffing. He initially recommended a larger 2.5" overlap, but I reduced it to 1.5". I see no wear after 2 seasons cruising and light racing (but in vigorous conditions).
I will ask about the sacrificial strips, it's a good idea. But to be honest, if there was wear, I'd simply have it repaired. Wear is a normal part of a sail's life and I don't realistically expect one to last 20 or 30 years. The benefit of the 2+2 configuration and full roach are too great for me to consider going back. When properly trimmed, this sail rocks. It's the one that you see above.
Sabre 38 "Victoria"
