Sea anchor or Drogue - Page 2 - SailNet Community
 5Likes
post #11 of 17 Old 03-08-2013
Bristol 45.5 - AiniA
Re: Sea anchor or Drogue
Originally Posted by jackdale View Post
Drogues and sea anchor can cause the same debate as an anchor thread.
At least most people have actually used an anchor of some sort. The number of people who have actually used a sea anchor or drogue is pretty small.
We have a parachute system with the gear recommended by the Pardeys but have never used it. Would like a drogue system since we might use it more often, e.g. long before survival conditions, more for comfort and to reduce wear and tear on the boat.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
post #12 of 17 Old 03-08-2013
I have no personal experience with this but from everything I've read a sea anchor is used as a last resort. It's for when all hell has broken loose & you're in survival mode. A drogue is for when you want to keep sailing & the waves are from the stern. The drogue slows you down enough so the waves pass under you & you're not surfing down the crests.
I would spectulate that the use of a sea anchor would require a serious re-enforced attachment point.
I'm not happy unless I'm complaining about something.
I'm having a very good day!
misfits is offline
post #13 of 17 Old 03-08-2013
Both require serious attachment points and the drogue is also for survival situations. No one would deploy it casually, as its close to impossible to retrieve. Imagine suddenly surfing backwards down a wave because your anchor came out of the next wave.
The say no one has ever lost a boat with a drogue deployed. Sea anchors can be pulled out of the face of an oncoming wave and lurch the boat doing damage.
Jeanneau 54DS
Minnewaska is offline
post #14 of 17 Old 03-08-2013
outbound's Avatar
Bought a Jordan series drogue from the folks in England. Delightful to work with and very straight forward. Quality of device is such I'm glad I did not buy a kit and do it myself. Have boat set up so bridle attachment points are far apart and chaff minimized. Deployment bag is quite clever and would allow even a fat old man like me to deploy it by myself. Hope the creek don't rise and it always stays below. Can use a rolling hitch on a piece of small stuff and then the primary to winch back in and replace in deployment bag. Wash down with fresh water at later date. From what I read a series drogue is more likely to allow survival even in cyclical storm setting.
s/v Hippocampus
Outbound 46
outbound is offline
post #15 of 17 Old 03-11-2013
Master Mariner
capta's Avatar
I think it's pretty simple. Drogues keep the boat moving and under control and sea anchors are used when there's no one to steer. However, and I can't stress this enough, if you use a sea anchor, you are risking your steering. You are being pushed backwards by some pretty powerful forces (like who uses a sea anchor in calm conditions?) and no matter how you secure the helm, the steering (cables, rudder or tiller) is at grave risk.
In most conditions which I've considered serious enough to use either, I have laid a-hull, hove to or run under bare poles, though I carried a drogue on my circumnavigation. I no longer do, but could cobble together something w/ nearly a 1000 feet of anchor line and lots of anchors aboard. I think a tire w/ chain wrapped around and shackled to the line w/ a splice and thimble is just fine and you can change the tire size for each boat; don't spend a lot of money.
capta is online now
post #16 of 17 Old 03-11-2013
Omatako's Avatar
Yep drogues/sea anchors and anchors is about the same, there will be differing opinions which will all be right for the people who hold them.
Personally I will never lie bow-on to a sea anchor for reasons of steering gear already mentioned. My probably naive view is that if the boat is moving with the weather no matter how slowly, it has to be better than standing still and taking what comes.
Having had a 35ft swell break and send 10ft of white water onto my boat, I wonder about the ability of a parachute to stop the boat going backwards and threatening the steering systems.
Bare poles is no good - my boat easily does 9 knots downwind under bare poles on 75+ knots (been there) and at that speed it surfs. There are some on this board that say they love surfing their boats but a 44ft boat taking off down a swell of unknown but obviously very large proportions in the dead of night takes a very stout heart, better than the one I have.
So for me it's a drogue that keeps the boat at 4 - 5 knots, stops it from surfing and allows me to travel with the forces that are threatening to kill me rather than wait around for them to achieve it. Drogues are also easier to recover than parachutes - I am putting a small capstan on the aft deck for this purpose. I'm getting too old to manually recover either.
I wouldn't know where to stow a tyre wrapped in chain - I have 140 metres of 30mm line (old superyacht jib sheet) with big knots tied every 10 metres. It slows my boat from 10 knots to an stable, manageable 4. Frankly, I don't know where I'm going to stow that either but it is a lot less agricultural.
Different strokes, different folks, there will no doubt be many who disagreee with the above - I don't care.
chef2sail likes this.
Arthur C. Clarke
Omatako is offline
post #17 of 17 Old 03-11-2013
chucklesR's Avatar
Having read the aforementioned thread - and a lot of blogs and logs - I would think that it's still really depends on the boat for which is best.
Coming from a catamaran background my preference is a drogue (or a warp) to slow me down. That allows me to be active, if I can be active.
It's also a little easier to retrieve once you stop needing it.
chucklesR is offline
Making a Drogue 71Irwin32 Gear & Maintenance 1 06-10-2012 01:48 PM
jordan series drogue kimberlite Gear & Maintenance 33 08-04-2011 10:14 PM
series drogue chain plates Snboard976 Gear & Maintenance 2 11-28-2008 04:19 PM
Jordan series drogue magnusmurphy Gear & Maintenance 23 05-22-2007 04:41 PM
drogue vs sea anchor kimberlite General Discussion (sailing related) 9 08-28-2001 07:59 AM
