Insulation - SailNet Community
 2Likes
post #1 of 15 Old 03-08-2013 Thread Starter
flandria's Avatar
Dock
Insulation
We're sailing on Georgian Bay where things are always still quite cool in May and early June, (with temperatures below freezing overnight in early May) but our season is short so we try and get started early. When we purchased our Catalina 36MkII we also got Espar diesel heating installed to help extend our season. Great idea, but not so good in reality.
The problem is condensation, with everything dripping in no time flat, from the un-insulated ceiling and especially the (metal frame) hatches.
I do not believe that there is a real solution to this problem. It would take quite bit of work to do a good job installing a false ceiling, which would not get rid of the insulation from the hatches. However, I am putting this out here for comment in case you folks out there have a smart idea about this!
flandria is offline
post #2 of 15 Old 03-08-2013
Puget Sound Pounder
kellysails's Avatar
Re: Insulation
I have a bit of the same problem. Someone on another thread suggest this. I am not so sure but maybe.
Reflectix BP24050 24-Inch-by-50-Foot Bubble Pack Insulation - Amazon.com
kellysails is offline
post #3 of 15 Old 03-08-2013
chucklesR's Avatar
Re: Insulation
Not that it helps any, but MOVE
Silvio and jimgo like this.
chucklesR is offline
post #4 of 15 Old 03-08-2013
BluemanSailor's Avatar
Re: Insulation
Lived aboard my former boat for 2 years in Philly- year around. Used that material and installed a good heater (Webasto) had very little condensation problem.
Roland
Sailor - kayaker - woodturner - Photographer.
New boat sailblog -
BluemanSailor is offline
post #5 of 15 Old 03-08-2013 Thread Starter
flandria's Avatar
Dock
Re: Insulation
Thanks, KellySails... I rather doubt that bubble pack will be "neatly installed" but may be useful inside cabinets against the hull.
ChucklesR... good point, but, after the divorce, I probably have no boat to worry about any condensation within it... And, the sailing and scenery is quite good while the season lasts...
flandria is offline
post #6 of 15 Old 03-08-2013
SchockT's Avatar
Re: Insulation
A good insulation for boats is Armaflex sheets. You should be able to find threads on that topic. I am surprised your Catalina doesn't have a headliner. Wasn't that standard on Cats?
As for your condensation problem, you need to reduce the relative humidity in your boat. The easiest way to do that is to introduce more fresh air into the boat, and exhaust some of the moist air. Modifying your heating system so that it draws some outside air into the return air of the heater may help. The positive pressure created by the addition of outside air will naturally force some of the moist air out through a vent or partially open port light. The last thing you want is to seal up the boat tight. Fresh air is the key.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #7 of 15 Old 03-08-2013
Re: Insulation
Flandria, there are only two ways to get rid of condensation. Get rid of the moisture in the air, or keep it away from the cold materials. No magic. So either you need to supply more heat, which will drive off some humidity and heat the interior past the condensation point, or you need to dehumidify, or you need to insulate the overhead. That's probably the most practical, to look at insulation sheets or padding, and to use removeable inserts to "plug" the hatches as well. Just a piece of closed-cell foam with velcro on the sides may be all you need for that. If you need the light to come through, try layers of the smaller bubble-wrap instead.
This is one for "brute force" though. Heat, or insulation, and you keep going until it stops dripping.
hellosailor is offline
post #8 of 15 Old 03-08-2013
Re: Insulation
There's a ton of threads on this subject here with alot of good advice from liveaboards like WingnWing. Try searching the site, you'll find some good stuff to address your problem.
I'm not happy unless I'm complaining about something.
I'm having a very good day!
misfits is offline
post #9 of 15 Old 03-08-2013
Barquito
Barquito's Avatar
Re: Insulation
Reminds me of the story Lin Pardey tells of waking up in the morning to find her hair has frozen to the condensation against the bare hull.
Valiant 32
Barquito is offline
post #10 of 15 Old 03-08-2013
Re: Insulation
I've lived aboard in BC year round, for decades, in extreme comfort. The trick is lots of foam insulation sprayed into my steel hull. Any piece of steel the size of your fingernail which is not covered by at least a half inch of foam will drip like a leaky faucet. I believe fibrglass is not much different in that regard . A friend who sold his spray foamed steel boat and bought a fibreglass one said living in the fibreglass hull was like living in a block of ice, by comparison.So the trick is start cutting and gluing in foam, a bit at a time. The thicker the better. You can do it over time and each piece of foam you glue in will improve the comfort level.
A false ceiling with an open air space is not much insulation, and wont do much.
Brent Swain is offline
Insulation ... Cal28 Gear & Maintenance 1 11-14-2009 09:36 PM
Insulation? T37Chef Gear & Maintenance 17 01-28-2009 11:06 PM
Insulation Popeye77 Living Aboard 0 10-09-2008 11:21 PM
Ice box insulation obiec Gear & Maintenance 1 08-12-2003 01:12 PM
Insulation JMWyatt Gear & Maintenance 0 01-20-2001 10:39 AM
