Popularity of center cockpits? - Page 3 - SailNet Community
 8Likes
post #21 of 50 Old 03-10-2013
blutoyz's Avatar
Re: Popularity of center cockpits?
My buddy has an Irwin 44' and the passageway aft is below the cockpit. There is a benefit with the cc when it comes to docking I will admit. When you stand on the aft deck the sheer size of his boat is intimidating but from the cockpit it really isn't so daunting.
He is the one that hooked me into this hobby after sailing his boat...it was a little tough to weather but it was the first thing that I sailed since the small boats as a kid so I will chalk it up to inexperience.
blutoyz is offline
post #22 of 50 Old 03-10-2013
Bristol 45.5 - AiniA
When we were looking for our current boat for extended cruising we started by looking at aft cockpit boats in the 42 to 44 foot range. To get any sort of room in the aft cabin they all had enormous bridge decks - if you can call it a bridge deck if it is at deck level and six feet long. One, Hylas 42?, actually had two cockpits with a footwell forward where the companionway was. A Swan 43 had an enormous number of steps (9 or 10) from the deck to the interior after you left the cockpit and went forward several feet. Can't imagine doing that routinely on a passage at night when it is honking. This was just a deal breaker and it was on some really nice boats. A CC makes sense in the 37 to 50 foot range if you want a really nice aft cabin.
BTW, some older Moodys in the 34' range have done a remarkable job of building a CC of this size that does not look like a wedding cake.
Finishing our major refit. Our trip to Newfoundland is off because it is too late. Hoping to go to the North Channel instead.
killarney_sailor is offline
post #23 of 50 Old 03-10-2013
chucklesR's Avatar
For a cruiser, Center Cockpits reign supreme.
Two things I learned while sailing catamaran's- you can't see the boat while you are sailing it, and everyone at the raft up comes to your boat because it's simply got more room.
Seriously, what's not to like:
seafrontiersman and olddog60 like this.
chucklesR is offline
post #24 of 50 Old 03-10-2013
olddog60's Avatar
Ok, what about this looks like a wedding cake? gonna get wet under anything but nasty conditions? Pooped, not easily, and I sleep like a baby. I forgot stand up engine room.
olddog60 is offline
post #25 of 50 Old 03-10-2013
chef2sail's Avatar
Center of motion is higher. That factors in in comfort in the seaway.Not as much an issue on larger boats.
Whats with the lexan in the hull are those really windows?
dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #26 of 50 Old 03-10-2013
theartfuldodger's Avatar
Send a message via Skype™ to theartfuldodger
My wife and I found our CC 42 Passage and live aboard full time we would not let her go and have been already offered more than we paid for her a couple of times. Greast boat to live on and cruise aboard.
Brake Free
Lake Ontario
42 CC Passage
theartfuldodger is offline
post #27 of 50 Old 03-10-2013
Learning the HARD way...
eherlihy's Avatar
C/C doesn't generally work as well for boarding from a sugar scoop, A/C interiors feel bigger than C/C layouts - less corridor space.
and C/C's typically have more freeboard than an A/C, which could make maneuvering into a slip more exciting in the C/C when the wind pipes up.
[EDIT] Although I gotta say that I like the looks of the S/V Chuckles.
eherlihy is online now
post #28 of 50 Old 03-10-2013
olddog60's Avatar
dave
The cockpit is deep IMO. I believe this puts me on the level of most aft cockpits. In some cases lower. If not it is real close. Either way I see little if any difference in comfort level. When standing I can barely see over the Hard Dodger. Take a look at my avatar it is deep ~4 ft.
Yes those are fixed windows. Not a great idea for some, there is no history of any problems.
olddog60 is offline
post #29 of 50 Old 03-11-2013
chef2sail's Avatar
The cockpit is deep IMO. I believe this puts me on the level of most aft cockpits. In some cases lower. If not it is real close. .
That is interesting claim. Must be an optical illusion. Would be interesting to measure where you cockpit seats are in realtionship to the water and compare. Maybe I have been fooled all these years.
Ive never got the feeling those in a center cockpit were istting down like in a tank peering over a bulkhead. Your height over the sole in the cockpit is no less than the height in an aft cabin vessel. The 36 CC Bene is in the slip right next to me. His cockpit is substantially higher. The 45.5 Bristol in our club is a few down for me...same thing. S/V Auspicious beautiful CC Halberg Rassey was docked beside me in a slip once. His cockpit was definately elevated from my aft cockpit. His boat is an example of a finly designed CC at 40 ft. Isnt that the advantage when docking,,,better sight lines because you are not only in the center, but elevated?
A Passanger can stand under it. Many aft cabins dont have the same room. It is the inherent advantage of the CC...the expansive rear cabin because the bridge and cockpit are not above it. The CC cockpit is above something, galley, salon, etc and you arent stooping under it
I like a properly designed CC like I said not a converted CC from an aft cabin set up.
Parkville, Maryland
Our blog-
post #30 of 50 Old 03-11-2013
olddog60's Avatar
I am sure I don't know or have seen as many boats as most on this site. That being said I am higher than a Cal 40 next to me and about even with a sugar scoop 46 Hunter in front of me.
Looking at pics of the HR 40cc I think it is about the same as my Bene. My Hot tub as some call it is deeper than you might think. The cockpit/tub sits over the engine room.
Motion comfort has not been a issue for me and the admiral and that was what started this conversation.
Fair Winds,
Tom
olddog60 is offline
Looking at 420,450,456 Hunter Center Cockpits. RatHatDiver Hunter 4 04-30-2012 05:22 PM
Center Cockpits sailingfool General Discussion (sailing related) 4 11-19-2006 08:36 PM
Center cockpits +''s & -''s DelmarRey General Discussion (sailing related) 9 11-30-2002 06:43 AM
center cockpits jiffy feet Living Aboard 15 11-18-2002 08:20 AM
O''day and Irwin, cheap center cockpits?? freewill Boat Review and Purchase Forum 1 01-25-2001 06:39 AM
