EPIRB or PLB for coastal cruising - Page 4 - SailNet Community
 7Likes
post #31 of 36 Old 03-22-2013 Thread Starter
Senior Smart Aleck
jameswilson29's Avatar
Re: EPIRB or PLB for coastal cruising
I believe you are misinterpreting the statement is not intended for operation IN water - that is the difference between an EPIRB and a PLB. Although it floats and it is waterproof, you cannot drop it in the water and expect to be saved. You have to wear it, with the antenna above water, just like every other PLB.
If it were designed to be operated IN water it would be an EPIRB. ON the water is different from IN the water.
It is designed for marine or terrestrial use.
As I have said several times on this listserv, I am not so gullible as to pay $100 extra because something has "Marine", "Aqua", or "Yacht" in the name.
jameswilson29 is offline
post #32 of 36 Old 03-22-2013
Junior member, rest old
msmith10's Avatar
I also bought the ACR 375 but I got the older, non-buoyant model. It's a little smaller, which means I'll wear it. Nonbuoyant so I have to be sure it's tethered to me. I put it in a case which attaches to my vest/harness. The only thing I don't like about the design is no integral attachment method to wear it. The firefly strobe has built in rings so you can attach it to your vest or body- the PLB doesn't, which I think is an oversight.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #33 of 36 Old 03-22-2013 Thread Starter
Senior Smart Aleck
Anyone who is not convinced about the intended purpose of the ACR 2881 should go to the ACR website, Product Wizard finder, my intended usage provides both the ACR 2881 and the ACR 2882 as appropriate products:
Product Wizard | ACR ARTEX
Finally, in the media links, 2 different photo advertisements show a boater in the water, one obviously in the ocean: http://www.acrartex.com/products/cat...lus/#tab-media There are no photos of terrestrial use.
chef2sail likes this.
post #34 of 36 Old 03-22-2013
jackdale's Avatar
The main difference between a PLB (24 hours) and and EPIRB (48 hours) is battery life. Some EPIRBS are manual, they have to be released and triggered.
Auto or Manual EPIRB?
But it is your choice.
jackdale is offline
post #35 of 36 Old 03-22-2013 Thread Starter
Senior Smart Aleck
I respectfully disagree. While battery life is one difference, the primary difference is whether the unit operates floating on its own, or whether it must be held above water/attached to a person.
By the way, older ACR ResQLink products have been COSPAS-SARSAT approved. This is a relatively new PLB model.
post #36 of 36 Old 03-22-2013
jackdale's Avatar
The differences between EPIRBs and PLBs
Personal Location Beacons work in exactly the same way as EPIRBs by sending a coded message on the 406 MHz distress frequency which is relayed via the Cospas-Sarsat global satellite system.
However, there are a number of differences between them. PLBs are designed to be carried on the person so they are much smaller, some such as the Fast find are not much larger than the size of a mobile phone. PLBs are designed to be used anywhere in the world, on the sea and also on land. Some don't float but may come with an additional floatational sleeve which they should be carried in.
PLBs, once activated, will transmit for a minimum of 24 hours; while the battery life on an EPIRB is at least double (a minimum of 48 hours). An EPIRB is registered to a vessel, whereas a PLB is registered to a person. This means that if you are crewing a yacht and you swicth to a new yacht the plb is still correctly registered; however, if you have an EPIRB and buy a new yacht you will need to re-register it when installing in your new boat.
Since I do not own a boat I carry an PLB (Aqualink). It floats and is waterproof. It also has a clip to attach to my pfd and a lanyard to prevent loss.
On ocean deliveries we have an EPIRB.
jackdale is offline
Cat 27 enough for coastal cruising? jkiser General Discussion (sailing related) 16 12-14-2011 10:52 AM
Louisiana Coastal Cruising AlwaysFORSAIL Cruising & Liveaboard Forum 1 12-01-2006 02:52 PM
coastal cruising a Santana 35 uncleal Boat Review and Purchase Forum 1 09-22-2005 03:18 AM
Coastal Cruising Mexico Singaporesam Boat Review and Purchase Forum 1 06-03-2002 01:35 PM
