current boat fitting interior mirrors/glass? - SailNet Community
post #1 of 4 Old 03-13-2013 Thread Starter
boz86's Avatar
Hi,
Refitting a 84 era boat with new mirrors and sliding glass, and the old material (acrylic with mirrored laminate backing) seems to be hard for my glass supplier to find.
What is the current standard? Tempered glass mirrors? Something else?
Thanks,
Boz
"The Stone Age did not come to an end because we ran out of stone." Sheikh Yamani
boz86 is offline
post #2 of 4 Old 03-13-2013
Moderator
Jeff_H's Avatar
Re: current boat fitting interior mirrors/glass?
I had no problem locating this material. Maritime Plastics in Annapolis fabricated mine from a pattern that I made from 'door skin' ply. A couple words of advice. I typically put self-adhering shelf liner plastic on the back of the mirror. Otherwise the silvering will be damaged by the motion of the boat wherever the plexi touches anything. I also make a small rabbetted 'plastic' base so that the edge of the mirror cannot touch water on the counter.
Jeff_H is offline
post #3 of 4 Old 03-13-2013 Thread Starter
boz86's Avatar
Thanks, I was trying to use a fabricator I found closer to home. If they don't go through I'll make the run to Annapolis.
boz86 is offline
post #4 of 4 Old 03-13-2013
Senior Moment Member
SloopJonB's Avatar
The stuff is available from any decent plastics supplier/fab shop. I just finished using 1/8" mirrored plexi to line the well of a big skylight I had installed on our house. My small supplier had some in stock but not enough so he had to order it in - couple of days. It's easily available in 1/8" and 1/4", I'm not sure about thicker sizes. Costs about $200 for a 4 X 8 of 1/8" (here).
If you cut your own on a table saw or router table, do it face down - the face has protective film but the back side doesn't and it scratches easily. If you use a jig saw, do it face up. Lot's of teeth on the cutter and slow speed or it will melt rather than cut its way through.
SloopJonB is offline
Retro fitting a propane locker in a small sail boat downeast450 Gear & Maintenance 47 05-25-2016 05:13 PM
Cal 21 Glass bottom boat? bonito Cal 0 09-06-2010 03:23 AM
Boat Values in the current market Duckwheat Boat Review and Purchase Forum 21 07-12-2010 08:13 PM
fitting a bare boat on a budget. orionmetzger Gear & Maintenance 10 04-28-2009 06:26 PM
fiber glass fuel tank new fitting obiec Gear & Maintenance 1 01-25-2003 08:50 PM
