Weatherfax audio file for testing - Page 3 - SailNet Community
 6Likes
post #21 of 40 Old 03-15-2013
Re: Weatherfax audio file for testing
Originally Posted by rockDAWG View Post
Exactly, 10x
Actually, Black Cat has address this.
image deleted
iPad / iPhone / iPod Touch Microphone Adapter Wiring Diagram
The also posted another source - ready made solution. So I will look into it to see if it will work.
iPhone 1/8 inch line-level audio input adapter - 3.5mm 4 conductor TRRS Male to 3.5mm TRS Microphone Input Jack with built-in Attenuator
I don't really understand this. That iphone port is for headsets, meaning an output. How can it be used to accept input from an external source?
I thought someone may make a cable to connect to the rectangular port that is used for communication in both directions and charging.
Jeanneau 54DS
Minnewaska is offline
post #22 of 40 Old 03-15-2013
Originally Posted by smurphny View Post
It does seem pretty archaic but I guess the population that uses hf is not big enough to spur tech geeks to do much research and invention......
That's probably it, but Pacor still seems to be in business. If I were them, I would think making the use of their device simpler, would sell more. Not to mention its free weather. No 3G subscription or wifi needed, so it would be useful to coastal cruisers too.
Jeanneau 54DS
post #23 of 40 Old 03-15-2013
Originally Posted by RichH View Post
..... might be something for Sirius-XM radio to consider, huh?
They already have it. We have XM weather download into our aircraft. It's about $60 per month. Marine version available too, but also has a subscription and hardware cost. I believe late model chartplotters are designed to overlay the input.
Jeanneau 54DS
post #24 of 40 Old 03-15-2013 Thread Starter
美国华人, 帆船 教授及输送
To my understand you need the Camera Connection adapter for iPAD.
In their site, it says:
With the Camera Connection Kit, you can plug a USB sound input device into the iPad, and use a patch cable between it and the radio's audio output. This is by far the best solution.
Fine Print:
I am old school. Integrity is to do the right thing even when no one is watching.
rockDAWG is offline
post #25 of 40 Old 03-15-2013
Seņor Member
ottos's Avatar
Don't forget about the microphone part of the headset...that seems to be what they're utilizing.
ottos is offline
post #26 of 40 Old 03-15-2013
Over Hill Sailing Club
smurphny's Avatar
There are some land-based packet modems but Pactor, in Germany, seems to be the only one making them focused on the boating population. At around $1400 bucks, they really are out of the mass market price range. I don't even like to think about how much money I spent on the SSB system. Hopefully it will last for a while and not become obsolete too quickly.
smurphny is offline
post #27 of 40 Old 03-15-2013
Of course. (Smacks palm on forehead)
Now that I think about it, the attachment to the Pactor modem should be Bluetooth. Dial in the freq on the SSB, fire up the modem and the ipad should connect itself. The rest should be a single tap on the screen. This has to be possible.
Jeanneau 54DS
post #28 of 40 Old 03-16-2013
Mermaid Hunter
SVAuspicious's Avatar
Originally Posted by jackdale View Post
Tell me about that "big hunk of copper wire".
I am thinking about a similar setup to use on my trips around Vancouver Island. Few of the boats have SSB.
My big hunk of copper wire carried on delivery is the end of a spool I bought in the mid-70s from Lafayette Radio Electronics. It was sold as "antenna wire."
Any 12 gauge (+/-) wire will work. Insulated is probably better for our application. I'd get something tinned for a permanent installation but for a go-bag it doesn't make much difference.
I run it up as high as I can and try to get 50 or 60 feet out straight(ish).
For the Kaito 1103 you connect the wire to the tip of a 1/8" male mono plug, insulating it from the ring. Just plug it into the external antenna connector. Watch the audio connectors -- most laptops have a mono mic input and the headphone jacks on shortwave radios including the Kaito are often stereo.
I use JVCOMM32 for weather fax demodulation and display.
jackdale likes this.
SVAuspicious is offline
post #29 of 40 Old 03-17-2013
smurphny's Avatar
I use a split lead antenna. It has the advantages of being able to roll it up and stow it when the boat is in storage and also eliminates the need to splice so many failure points into your backstay such as in a standard insulated stay antenna. GAM / McKim Split Lead Antenna | GAM Electronics For portability, this might be a good option.
smurphny is offline
post #30 of 40 Old 03-19-2013
Mermaid Hunter
For whatever it is worth I am not a fan of that product. It works on some boats and is a dismal failure on others. The lack of predictability makes me unhappy.
Help with WeatherFax and SeaTTY desierto Gear & Maintenance 5 10-03-2015 11:56 AM
Weatherfax frequencies davejq Gear & Maintenance 4 02-13-2010 11:20 AM
Whne having trouble with file formats, save the file in a RTF (RichT NewsReader Mass Bay Sailors 0 05-21-2006 10:15 AM
e-mail / weatherfax? richardrhatigan General Discussion (sailing related) 2 07-27-2005 08:25 AM
ssb/weatherfax/pc based Navigation chuck711 Cruising & Liveaboard Forum 2 01-12-2003 03:15 PM
