c&c 99 hull survey question - SailNet Community
 1Likes
  • 1 Post By killarney_sailor
post #1 of 6 Old 03-15-2013 Thread Starter
[This was posted to another less active forum, not Sailnet, so my apologies if you have seen this question before.]
I had a 2002 C&C 99 hauled out for a survey today knowing that in December 2012 a survey found a void on the starboard side just below the waterline about 1 foot by 6 feet long which was repaired (the core was found to be dry so epoxy was injected and the entire hull was re-tapped afterwards and found to be good.)
Today, the new surveyor found two voids about 12x18" each to the aft of each side of the saildrive (just ahead of the lift straps.) This was obviously a surprise because of the prior survey and repair work that was done. The voids today were very obvious so we had the original surveyor come back and he believes they were not there when he did the original survey and re-survey after the repair.
I don't know if the issue is sections of dry laminate (never received resin during the vacuum bagging process) or if the resin-ated core area bonding is failing (which would be worse.)
To get straight to the point, have the seller fix it and go forward or walk away (or run away if that's the appropriate response)?
Thanks, Brian
brianc is offline
post #2 of 6 Old 03-15-2013
Bristol 45.5 - AiniA
Re: c&c 99 hull survey question
I would walk unfortunately. You don't want to own a boat that gives you a voice in the back of your head wondering if all of the problems in the hull have been fixed.
rugosa likes this.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
post #3 of 6 Old 03-15-2013
Senior Smart Aleck
jameswilson29's Avatar
Every buyer should research the boat he or she intends to buy. Research Tartan and C&C lawsuits.
jameswilson29 is offline
post #4 of 6 Old 03-15-2013
I'd walk... if this is a progressive issue, you can fix 'these ones' but others will likely crop up the next time you haul.. how can you know that all the bad spots have been addressed - esp since the currently offending areas 'tapped out OK' last time.
Faster is offline
post #5 of 6 Old 03-15-2013 Thread Starter
Thanks for the replies. I'm going to walk, there's just too much risk.
The boat in question was produced the same year as the C&C 121 that had so many problems, and while there isn't any hull cracking on this boat, the root cause seems like it could be the same, especially with the appearance of the new and large voids (there was actually a third void identified around the back-stay chain-plate which I forgot to mention earlier,) maybe 'progressive' as Faster mentioned, will eventually mean the whole hull...eek.
Assuming there was a real issue, if there was a fix implemented, does anyone know which hull numbers/years are the problems?
I can't find that information so unfortunately, that probably means I'll avoid all of them.
brianc is offline
post #6 of 6 Old 03-15-2013
tommays's Avatar
EVERYBODY that does resin infusion has some amount of less than perfect results and it is NOT like there making thousands and can afford to chuck a marginal hull and there is really no way to fix it
Even on a CNC machine were everything is very controlled a certain amount of stuff hits the reject bin
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
Tags
c&c , epoxy , hull
Winter survey question AuntB Boat Review and Purchase Forum 5 12-18-2010 05:06 PM
Survey Question doubleeboy Boat Review and Purchase Forum 2 09-15-2008 10:48 AM
Survey Question steveg353 Boat Review and Purchase Forum 4 06-24-2008 05:56 AM
Hull and Mechanical Survey around MD thomaskennedy Boat Review and Purchase Forum 5 05-02-2007 12:51 AM
