-   -   How do you heave to with main sail alone? (http://www.sailnet.com/forums/general-discussion-sailing-related/97622-how-do-you-heave-main-sail-alone.html)
matthewwhill 03-16-2013 02:12 PM
Could someone please explain how you heave to with a main sail alone?
I've read a number of confusing and contradictory explanations in a few sailing books.
Thanks!
Faster 03-16-2013 02:20 PM
Re: How do you heave to with main sail alone?
The few times we've tried that we ended up near head to wind, sheeted hard, rudder locked and the boat would pinch up a bit stall fall off and gentle round up, sat there doing very slow scallops at minimal speed.. But serious wave action would likely upset that delicate balance and I imagine that some boats won't do it well... Trial and error will tell.
matthewwhill 03-16-2013 02:24 PM
I was out yesterday in 15-20 and I sheeted the main hard and let the tiller go and swing freely. I would head up and tack, then weather healm would build up in the other direction, I would tack back... and so on. Back and forth. Seemed to work well. But there wasn't much wave action....
Alex W 03-16-2013 03:06 PM
Faster's method is what works well on my Pearson. I haven't had luck heaving to with the jib up, but I haven't tried since having working jib reefing (my previous system couldn't reef).
Fin keel boats with spade rudders generally don't heave to as nicely as a full keel boat, but they can do it. You just need to experiment.
brokesailor 03-16-2013 03:22 PM
I thought when you use the mainsail alone it's actually fore reaching.
matthewwhill 03-16-2013 03:32 PM
Brokesailor-
You are probably right... can you explain fore reaching?
Sal Paradise 03-16-2013 04:03 PM
I've done forereaching with just the main and you just barely creep forward sheeted tight almost stalled out pointed into the wind. Almost in irons.
RichH 03-16-2013 06:17 PM
If youre forereaching when hove to only with a deep reefed main ... you'll need to pull the traveller more to windward until you counter balance the forereaching. Too much traveller to windward and you'll start a stern-way, too little and you'll forereach ... slowly drifting forward. .... If 'perfect', you want to be able to develop a 'turbulence slick' in the water to windward which will 'pre-dump' / cause oncoming breaking waves to 'trip themselves' in that 'turbulence slick'.
Yup, a long keeled boat will do better with being hove to on only a deep reefed main than a fin keeler.
brokesailor 03-17-2013 07:19 AM
If you get a copy of Hal Roth's " Handling Storms at sea " there is a whole chapter dedicated to Fore reaching. (No affiliation!)
John B 03-17-2013 09:08 PM
I am a novice sailor and I am going to try to heave to this summer.I have read a lot about it ,and appreciate your posts. They are very helpful.
