1974 Catalina 27 - SailNet Community
 1Likes
  • 1 Post By jameswilson29
post #1 of 7 Old 03-17-2013 Thread Starter
1974 Catalina 27
Hello,
Not sure if this is the best place to ask this question. This 1974 Catalina 27 is an amazing boat in great condition and hope to buy it shortly.
It does require a new holding tank and the owner says...no problem replacing it. Is that in fact the truth? I'm hoping some one can help me locate and buy the proper tank.
Thank you all!
Kalina-Lona is offline
post #2 of 7 Old 03-17-2013
Senior Smart Aleck
jameswilson29's Avatar
Re: 1974 Catalina 27
Why does it need a new holding tank?
jameswilson29 is offline
post #3 of 7 Old 03-17-2013
chucklesR's Avatar
Replacing it is as easy as dumping boat bucks at it (301 of them):
Catalina Direct: Holding Tank For C-27 V Berth
There are other, suitable tanks available from Defender and the like that don't cost that much.
Actually removing the old and putting the new in depends largely on your skill set, your tool set, and/or the availability of yet another supply of boat bucks.
Make sure when reinstalling that it is held in place securely enough to hold it's own filled weight against the shock load of pounding into a head sea.
They do make glues for Poly tanks, you may be able to repair it.
chucklesR is offline
post #4 of 7 Old 03-17-2013
Senior Smart Aleck
I always wonder with this type of seller, if the repair is so cheap and easy, why didn't you do it before you put the boat on the market?
Let's face, you will be dealing with fittings and hoses that have carried fecal matter. I am not sure how anyone considers that to be no problem unless he or she is missing a nose.
rugosa likes this.
post #5 of 7 Old 03-17-2013
SchockT's Avatar
Yeah, I agree, why wouldn't he just fix it? Perhaps he is not handy, or just doesn't have the time, and is willing to discount the boat accordingly.
As for the job itself, sure it is smelly, but that shouldn't be a problem unless you are a serious WUSS! Every DIY boat owner has to deal with septic system problems sooner or later, and if you don't want to, then there are plenty of people who would be happy to tolerate the smell in order to part you from your hard earned cash! Just use your common sense, wear rubber gloves, wash your hands often and clean up the area with bleach afterwards. On a boat that old you might also consider replacing all of the hoses as well. Boats with old septic hoses develop a certain aroma that permeates everything and doesn't go away. Ripping those old hoses out and replacing them with new doesn't cost very much, and makes a HUGE difference to the air quality in the boat. (At least it did with mine!)
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #6 of 7 Old 03-17-2013 Thread Starter
Thanks,
There was a leak in the original they said. I was going to ask for it to replaced, but my concern is the finished project. They are working on a larger boat trying to be ready for the spring so I'd rather the price lower and do it myself, as long as it can be replaced.
Cheers,
post #7 of 7 Old 03-18-2013
norahs arc's Avatar
I replaced some of the hoses for the holding tank on my C27. It was not a "fun" job. I doubled the hose clamps as required but have to admitt that hose was so hard to work with that I think once it is on a fitting it would have to be cut to remove it. (I heated the hose ends or would never have got them on the fittings.) That said there is nothing technical about tank replacement but it may be more work than you expect.
Catalina 27 Aft. galley, dinnet L/O
Update - Sold Norah's Ark Buying A 24'Shark
Saint John NB
Canada
norahs arc is offline
1974 Cal 27 T2 PhilinTexas Cal 3 08-31-2013 11:42 PM
1974 Irwin 25' Help please mwadkins Irwin 2 10-01-2012 04:22 PM
1974 Rewire PaulSims C22 11 01-18-2012 01:51 PM
catalina 22 1974 new owner timothysplante Introduce Yourself 1 05-18-2010 10:03 PM
1974 28'' IRWIN SKIPPERPATRICK Boat Review and Purchase Forum 0 01-09-2004 12:17 PM
