Do I need a guy and a sheet on each side of spinnaker? - Page 2 - SailNet Community
 13Likes
post #11 of 31 Old 03-19-2013
jackdale's Avatar
Re: Do I need a guy and a sheet on each side of spinnaker?
Originally Posted by matthewwhill View Post
But for my education... Are the guys angled more steeply down to the hull than the sheets which are angled more shallow and aft?
Yes they are. The sheet are on blocks near the transom. The guys are on blocks mounted further forward.
jackdale is offline
post #12 of 31 Old 03-19-2013
RichH's Avatar
Yes! ... usually attached near the cap shroud bases ... or further forward.
A good 'trick' used by many performance large dinghy and planing hull boat sailors is to attach a stout deeply grooved and free spinning sheave to the cap shroud chainplate (need two holes - one for the cap shroud attachment and one for the 'axel' of the free spinning sheeve); to use you simply slip the lazy sheet under and into the deep groove of the sheave ... and the lazy sheet can then be used as a substitute foreguy. If using 'light line' tweakers many times simply pulling down on the tweaker (and a bit of tiller) will 'load' the lazy sheet into the deep groove sheave ... ditto when releasing from the sheeve.
RichH is online now
post #13 of 31 Old 03-19-2013
Once known as Hartley18
Classic30's Avatar
Dock
Hmm... not sure on your gadget description there, Rich - sounds awfully complicated!
Following the techniques you describe, dinghy sailors over here generally use what's known as a 'reaching hook':
..and lazy bigger boat sailors (like me!), who can't be bothered setting up 'tweakers' (I'll get around to it one day..), instead use a single very ordinary snatch block clipped to the cap shroud chainplate.
Classic30 is offline
post #14 of 31 Old 03-19-2013
RichH's Avatar
Yup, your 'reaching hook' is exactly similar to a deep grooved sheave 'axled' to a chainplate. Nothing complicated about either; the sheave has less friction thats all. ;-)
RichH is online now
post #15 of 31 Old 03-19-2013
Classic30's Avatar
Dock
Got a pic of your axled thingy? I'm having a hard time working out how that works out in practice...
post #16 of 31 Old 03-19-2013
matthew, you might want to get someone experienced out there with you, or to have someone else take you out for some spinnaker work before you try it yourself.
Simply because of the size and location, the spinnaker tends to be the most entertaining sail on a boat. Entertaining? Yes, it can be very entertaining watching them wreak havoc on other boats. And somewhat less entertaining when they try to eat your own boat. Think along the lines of Charlie Brown and the kite-eating tree. (G)
hellosailor is offline
post #17 of 31 Old 03-19-2013
Classic30's Avatar
Dock
Along the same lines, many forget that packing the kite properly before hoisting it is almost more than actually rigging it properly.
The number of times I've seen people 'wineglass' or hoist sideways is countless...
post #18 of 31 Old 03-19-2013
blt2ski's Avatar
We've hoisted the AS upside down per say! That is real interesting, especially once last summer, I kept saying we were going slow.....then I looked a bit more, something was wrong with the tack, it was too high, clew too low.......finally folks dropped and rehoisted, we gained a knot or two! oh well, race was well lost by then! LOLOL
marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #19 of 31 Old 03-19-2013
Originally Posted by jackdale View Post
Just a couple of things to add.
1) I always keep my main up. I may centre it if it interferes with the wind.
You dont' find this makes the boat want to round up? I'll over sheet for the jibe, but it always seems that The boat wants to spin out if I don't have the main trimmed properly.
I suppose really really deep this may not be as much an issue, but- my experience has been otherwise- how do you prevent the unwanted spinouts/ roundups?
c. breeze is offline
post #20 of 31 Old 03-19-2013 Thread Starter
Thanks again everyone!
Yes, I think it would be best to have someone with me or learn on someone else's boat. I don't plan on figuring this out on my own.... in 20 knot winds... in March.
matthewwhill is offline
relocating main sheet...just to one side? NewportNewbie General Discussion (sailing related) 6 05-25-2012 01:43 PM
Spinnaker sheet routing jarcher General Discussion (sailing related) 7 03-26-2010 07:01 PM
Spinnaker sheet barber haulers metch Racing 8 09-08-2009 08:49 PM
Need a jib sheet mwrohde2 Gear & Maintenance 23 12-30-2008 12:34 AM
Rigging Asym Spinnaker With Spinnaker Crane mr_lucky General Discussion (sailing related) 4 03-27-2008 04:14 PM
