Ham antenna for sailboat - SailNet Community
post #1 of 6 Old 03-19-2013 Thread Starter
Lightbulb Ham antenna for sailboat
Hello;
I recently bought a small fiberglass sailboat that I sail in the Pacific Ocean just off the coast of southern California. It has a 29 ft aluminum mast. I have not yet tried it, but I understand that HF radio transmissions propagate very well over salt water. I am thinking that it might be fun to take my FT-817ND radio with me and try some low power 20m contacting from a mile or two off shore. How do you think that would work?
With very little trouble, I could put a small vertical 20m mobile antenna atop the mast. Would that work better (over salt water) than the same antenna mounted at deck level? In either case, what can I do about grounding? I dont have a large metal mass (car) under the antenna and counterpoises for 20m are pretty long. I could trail a couple of buoyant radials off the stern of the boat in the water or instead of using a vertical, I could run a Par EndFedz wire antenna to the top of the mast. Any other ideas? What do you think might work the best?
Richard
Holder 20, So Cal
rlltrash is offline
post #2 of 6 Old 03-19-2013
Senior Smart Aleck
jameswilson29's Avatar
Re: Ham antenna for sailboat
I am thinking about wrapping the 30' wire antenna that came with my cheap SSB receiver around the backstay, but I have not yet figured out how...
jameswilson29 is offline
post #3 of 6 Old 03-19-2013
Here are some choices for marine antennas:
Marine Antennas
Click twice on each pic for full resolution. Start with the multi-color table on the upper left corner.
FYI, the best antenna you can put aboard for DX on 20m is a single-band VERTICAL dipole. Fed at the center with RG8X coax, you just hoist one end and tie the lower end off near the deck.
TRUE STORY: in the Virgin Islands a few years back I had my FT817 on my chest while relaxing in the cockpit at anchor. It was attached to a 20m vertical dipole on the bow. I made 2 DX contacts with 2.5watts (internal batteries) on SSB: a station in Armenia (gave me a 59 report) and a ZL in Aukland NZ (gave me a 57 report).
For QRP, especially, the antenna is EVERYTHING.
Yes, you can rig all manner of whips and such, but with only 5 watts you won't be very happy.
It makes no sense to put a vertical atop the mast. For HF verticals -- as contrasted with VHF verticals -- you want them mounted low down, close to deck in order to get the best low-angle radiation.
A radial for 20 meters is only 16' long. Use any kind of insulated wire.
With the dipole, you don't need radials or any ground at all.
Good luck,
Bill
WA6CCA
btrayfors is offline
post #4 of 6 Old 03-19-2013
No need to. Just clip it onto a shroud or the backstay. That's fine for reception.
Bill
post #5 of 6 Old 03-22-2013
Master Mariner
capta's Avatar
We used to use dipole antennas for my ham rig and though only a few pennies to make, they are absolutely the most efficient antenna you could use.
capta is offline
post #6 of 6 Old 03-22-2013
Daniel - Norsea 27
Rhapsody-NS27's Avatar
I'm thinking either a dipole, maybe 1/4 wave, raised on the mast at the center with the ends toward the bow and stern, or, a verticle raised up the mast and have a couple wires as counterpoise with one going to bow and other stern.
with the limited space availble on the boat, sometimes you have to be creative. Using a coil/trap on a dipole may help too.
Daniel
1981 Nor'sea 27,
Who is staring at the sea is already sailing a little.
-Paul Carvel
Rhapsody-NS27 is offline
VHF Antenna RobGallagher Gear & Maintenance 15 01-15-2013 04:52 PM
SSB wire antenna to antenna feed-line connector scud Electronics 0 09-24-2012 08:50 AM
What is this antenna? tausap Gear & Maintenance 11 03-26-2009 06:27 PM
wi-fi antenna westerly Gear & Maintenance 6 06-16-2008 09:23 AM
TV antenna Poinciana Gear & Maintenance 5 10-28-2007 03:01 AM
