New England Ropes Synthetic lifelines?!?! - Page 4 - SailNet Community
 10Likes
post #31 of 42 Old 04-06-2013
Re: New England Ropes Synthetic lifelines?!?!
The weight difference is less than that of a case of beer left on deck.
The price of used 1x19 is probaly less than the cost of high tech fibre.
1x19 is extremely smooth, and offers zero discomfort. I find the peace of mind it gives far more comfortable than synthetic line.
I havent found to hard to install, and once installed, you dont have to do it again for 30 years or more.
Agreed the weight is marginal, but it adds up
I can make an entire set of lifelines for less than the cost of the fittings on one wire lifeline. Even assuming that the synthetic has to be replaced more often, it is significantly less expensive.
Ever had your leg hair ripped out by wire? Or had stitches from meat hooks? I have had both, and trying to put in your own stitches 500 miles from shore is a bit uncomfortable.
I don't think wire is particularly difficult to install, so long as you have your own crimper, and somewhere to roll out the wire. I can splice a set of dyneema lifelines up then toss them in my sailing bag.
Greg
Stumble is offline
post #32 of 42 Old 04-07-2013 Thread Starter
NewportNewbie's Avatar
Chafe and UV resistance of stainless is far greater.
Maybe you didn't actually read about this rope. It's not just a strong rope that an be use for lifelines but NE ropes has designed it FOR lifelines. It's also covered so the core is strong while the cover is chafe an UV resistant.
One likes this.
S/V Cuajota - 1975 WD Schock Santana 30
NewportNewbie is offline
post #33 of 42 Old 04-07-2013
Over Hill Sailing Club
smurphny's Avatar
I replaced my coated wire with Dyneema a couple of years ago after noticing some cracks in the swaging and some corrosion through the coating. I did not want to worry about corrosion and swages again. They are light, strong, have no meathooks, and are a see-able quantity. There's no guessing about whether swages are good or not. The best solution would probably be eye-spliced bare wire. Brion Toss has a good method of splicing 1 x 19 wire in his book and a demonstration online. Brent is right about wire being tougher. You aren't going to slit it with a sharp edge. That's my main worry about the Dyneema. Once I become proficient at doing wire splices, I may start replacing all my swaged fittings, swageless and swaged, with splices.
As far as length of Dyneema lifelines goes, I would leave 6" and use lashing. That's what I did and it has worked out well. The lashing method allows adjustment for stretch. Dyneema does stretch over time. My 6" is down to about 5" now, maybe a little less. Another plus for Dyneema is being able to easily wrap them up and stow them in a locker. I spliced around 5/16" shackles at the gate ends. The shackles act as stops so that the gates, when secured put tension on the run.
jimgo likes this.
smurphny is offline
post #34 of 42 Old 04-08-2013
For what it's worth Brion Toss is on record saying he nor his shop will install wire lifelines anymore. They will only use dyneema. The reasoning he gives is that he considers wire dangerous, more expensive, and harder to inspect.
One likes this.
Greg
Stumble is offline
post #35 of 42 Old 04-08-2013
smurphny's Avatar
That's really the terrible truth about all swaged fittings--they cannot be visually inspected. There's no real way to know if water has penetrated, if corrosion has started, or for that fact, if the original crimp or installation has some sort of fault. These end terminals ALL give me the willies. My old furler has an integral Sta-Lok swageless base. I don't even like to think about it. Even all the new Suncor terminals I used when replacing the shrouds and stays don't give me the confidence that a sturdy, visible eye splice would. I would like to know what percentage of end terminals fail and for what reasons.
smurphny is offline
post #36 of 42 Old 04-10-2013
Evans Starzinger just posted a first draft of his take on this subject over on CA...
As always from he and Beth, an excellent, informed analysis and recommendations...
http://www.bethandevans.com/pdf/lifelines.pdf
JonEisberg is offline
post #37 of 42 Old 04-10-2013
What if you use some of the existing hardware, such as the turnbuckles (in lieu of lashings)? I love the look of the dyneema, but I hate to get rid of all of my hardware.
FirstCandC is offline
post #38 of 42 Old 04-10-2013
You can use it if you want. Johnson makes a very nice threaded eye that fits their standard gate hardware, they just want an arm and a leg for it. I probably wouldn't keep the turnbuckles, but the over center gate hooks are still commonly used.
Greg
Stumble is offline
post #39 of 42 Old 04-26-2013
I need to replace my lifelines and am considering the WR2 system...any suggested resources showing the best way to implement them? In particular I am interested in the best way to manage the gate. My current wire system has the typical double rings, I assume to maintain tension when the gate is open...I wonder if this is even necessary; a long line with a thimble forward (for tensioning) and a pelican hook (with rope adaptor) at the other end would be simplest (and cheapest). Any suggestions or best practices would be appreciated!
TIA!
paul323 is offline
post #40 of 42 Old 04-26-2013
Asleep at the wheel
jimgo's Avatar
Paul,
You might want to ask your question in a separate thread. Some people stop reading when the threads get too long.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
New England Ropes Mega Plait Arclight Gear & Maintenance 7 03-11-2010 09:33 AM
New England Ropes VPC j34035 Gear & Maintenance 7 10-28-2009 12:43 PM
Synthetic teak SpeedAgent Gear & Maintenance 5 02-16-2009 06:59 PM
Synthetic shrouds capedory30 Gear & Maintenance 2 02-10-2009 08:26 PM
AMSOIL synthetic sailnaway Gear & Maintenance 1 02-17-2006 02:38 AM
