Where is the grounding bus bar on a Pearson 26? - SailNet Community
Chat
Advertise Here
Go Back   SailNet Community > General Interest > General Discussion (sailing related)
Old 03-23-2013
rhr1956's Avatar
rhr1956 is on a distinguished road
Does anyone know for sure where the grounding bus bar is on a Pearson 26?
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 03-23-2013
Alex W's Avatar
no longer reading SailNet
Alex W is on a distinguished road
Re: Where is the grounding bus bar on a Pearson 26?
There should be one by the fuses/switch panel, but otherwise there likely isn't one with all fixed loads attached directly to the battery or battery switch. This is a good thing to fix.
My 1986 Pearson (a 26 is older) had a pretty antiquated electrical setup.
  #3
Old 03-23-2013
rhr1956's Avatar
Alex...my switch panel only has a positive feed coming into it. There is only one wire leading away from the (-) post on the battery. There is a bar somewhere-my guess it's located somewhere in the cabin but I haven't located it.
  #4
Old 03-27-2013
ccriders is on a distinguished road
On the p28 it is mounted on the starboard cockpit locker bulkhead.
You may post attachments
You may edit your posts
A very public grounding dylanwinter1 General Discussion (sailing related) 15 04-24-2012 04:18 PM
Grounding fmueller General Discussion (sailing related) 3 03-19-2012 10:40 AM
Grounding strips brokesailor Gear & Maintenance 12 10-31-2011 01:35 PM
Grounding Coreyboy18 Electrical Systems 11 05-02-2009 12:21 PM
Effect of grounding. chris_gee Sailboat Design and Construction 14 09-06-2008 07:56 AM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
