Easiest mast to raise? - Page 2 - SailNet Community
post #11 of 12 Old 03-24-2013
TakeFive's Avatar
Re: Easiest mast to raise?
This guy does it twice each outing - once to go under the bridge on the way out, and second upon returning. He uses and A-frame:
I do mine once a season while on the hard. I use a gin pole with retention straps as "baby stays" to keep the mast and gin pole in column. It could be done on water, although I'd worry if a big wake hit me while the mast was halfway up/down:
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
post #12 of 12 Old 03-24-2013
KIVALO's Avatar
Dock
The easiest mast to step is one that someone else steps!
I own a 260 and I can certainly step the mast alone but it is much easier with a second person. If you devise a system to run your "mast halyard" back to a primary winch I bet you'd have a simple time of it. Like anything, the more you do it the easier and faster it gets.
Brad
Originally Posted by RonTyson View Post
Hunter 240 or 260, a husband and wife did the Great Loop on their 260 several years ago including dropping the mast on the water going through the locks.
s/v KIVALO
2003 Hunter 260
"Any damn fool can navigate the world sober. It takes a really good sailor to do it drunk." - Sir Francis Chichester while loading his boat with gin.
WORK IS OVER-RATED
KIVALO is offline
New sail or raise sail position on mast? ehroe2 Gear & Maintenance 10 06-24-2012 04:41 PM
Easiest way to repaint the deck? NewportNewbie General Discussion (sailing related) 24 03-26-2012 03:08 PM
Easiest State Registration - Non-HIN ? kaakre Boat Review and Purchase Forum 21 11-22-2006 03:59 PM
Easiest 20-26 boat to raise mast on? Melelio Boat Review and Purchase Forum 3 07-11-2003 09:33 AM
Raise mast on 21 macgregor sach Gear & Maintenance 3 03-29-2002 03:59 AM
