Easiest mast to raise? - SailNet Community
post #1 of 12 Old 03-23-2013 Thread Starter
Anyone ever had a trailer sailor that impressed them with east of mast raising?
What about raising a mast on the water, as in launching on the Chicago river on a non-bridge lifting day, motoring up the river and raising the mast once I've made it past the LSD bridge?
TuurboSpaggetti is offline
post #2 of 12 Old 03-23-2013
rhr1956's Avatar
Re: Easiest mast to raise?
I had a West Wight Potter 19. Raising the mast was pretty easy for one person.
rhr1956 is offline
post #3 of 12 Old 03-23-2013 Thread Starter
Looking more for a 22 or 23 footer, but I will make a note of that. I won't be doing too much solo sailing though, so a 2 person raising job is certainly within reason.
post #4 of 12 Old 03-23-2013
Azzarac's Avatar
Take a look at the Macgregors. They are very simple to raise the mast on, and the X and M series come with a mast raising system for single handed raising. A lot of the older models have been modified to accept this system also.
“If you surrender to the wind, you can ride it.” – Toni Morrison
"Sic gorgiamus allos subjectatos nunc"
Follow Chameleon's travels at:
Azzarac is offline
post #5 of 12 Old 03-23-2013
Learning a bit every day
FinallySailing's Avatar
Hi, I have a Macgregor 26S. She came with her own mastraising system (ginpole). It can easily be managed by a half portion like myself. Always cracks me up when I'm at the marina and have to winch the mast up or down. A mast hanging in the air at 45 degrees seems to have a frightful attraction to other sailors who quickly run to the rescue, just to notice that everything is perfectly ok .
Whatever boat you end up with, a forestay lever helps to get the last free centimeters close enough that you can pin the stay in place IMHO.
FinallySailing is offline
post #6 of 12 Old 03-23-2013
Azzarac's Avatar
I'll second that on the Johnson Lever. Its a must have for anyone who raises and lowers the mast often.
Azzarac is offline
post #7 of 12 Old 03-23-2013
MarioG's Avatar
I had both the Chrysler 22 and 26 and on both the mast was easy to step.
Captain Scott Sailing Puget and Possession Sound Seattle Everett You can see it being done here
Endeavour E-32 "Samara"
I am the Capt of my ship but sometimes I think I had more fun just being the cabin boy.
MarioG is offline
post #8 of 12 Old 03-23-2013
captflood's Avatar
GREETINGS EARTHLINGS:- Had a Trident 24' triple keel cruiser/racer 34' mast raised and lowered single handed . Look on the trident owners association there are several designs for the tabinackles that are fitted to mast houseings. The one on board my boat was designed by my Farther and was out of two inch angl iron quarter inch thick in a u shape that fits over the outside of the upper tabinackle bolt . connecting the backstay the two shrouds and using the main-sheet attached to the spinicker halyard (3/4 rig) could up or down the mast in under and hour Hope this helps AS ALWAYS GO SAFE.
captflood is offline
post #9 of 12 Old 03-23-2013
Barquito
Barquito's Avatar
I would guess the Catalina 22 I had was about in the middle of the scale of easy to impossible to raise. It was a bit of work, but do-able with one person. It is always more difficult and dangerous to raise the mast on the water. The way I had the C22 set up it would have been a bad idea on the water.
Valiant 32
Barquito is offline
post #10 of 12 Old 03-23-2013
Hunter 240 or 260, a husband and wife did the Great Loop on their 260 several years ago including dropping the mast on the water going through the locks.
RonTyson is offline
New sail or raise sail position on mast? ehroe2 Gear & Maintenance 10 06-24-2012 03:41 PM
Easiest way to repaint the deck? NewportNewbie General Discussion (sailing related) 24 03-26-2012 02:08 PM
Easiest State Registration - Non-HIN ? kaakre Boat Review and Purchase Forum 21 11-22-2006 02:59 PM
Easiest 20-26 boat to raise mast on? Melelio Boat Review and Purchase Forum 3 07-11-2003 08:33 AM
Raise mast on 21 macgregor sach Gear & Maintenance 3 03-29-2002 02:59 AM
