Looking for a new hand-start diesel engine... - SailNet Community
post #1 of 8 Old 03-24-2013 Thread Starter
I have done some homework, but can't see anything definitive from the Volvo Penta MD1-13, I believe, or Yanmar. Anyone have any first hand experience with a hand-start diesel? I want to buy new...Thx in advance.
p1pel1ne is offline
post #2 of 8 Old 03-24-2013
Junior member, rest old
msmith10's Avatar
Re: Looking for a new hand-start diesel engine...
Only a little experience. I used to sail on a small Herreshoff with a little hand start diesel. OK if the engine access is from the cockpit but a nuisance if you have to go below to access it. Imagine running below to crank the engine coming into a marina. Worse yet if it dies while you're entering a crowded area and you need to go below to restart. Of course, once running a diesel isn't as likely to stall out as a gas engine.
I can hand start my engine (atomic 4) if necessary but I wouldn't give up electric start unless there was some compelling reason to do so. The ability to do both is ideal.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #3 of 8 Old 03-25-2013
CrazyRu's Avatar
what you need is not specific engine but non-electric starter, There are several options available, like spring starters, or pneumatic starters.
Spring starters Simms, Lucas, CAV mechanical starter motors from Kineteco Home Page
CR
s/v NEMO - Freedom 28 Cat Ketch, centerboard
CrazyRu is offline
post #4 of 8 Old 03-25-2013
Boasun's Avatar
lister out of UK makes nice hand cranked diesels.
open the compression release.
Crank hard
then close the compression release.
Note: this really builds your arms up.......
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Boasun is offline
post #5 of 8 Old 03-25-2013 Thread Starter
Thx, folks for the info...
p1pel1ne is offline
post #6 of 8 Old 03-25-2013
paulk's Avatar
We've tried to hand-start our Yanmar 3GM. Haven't been able to get it going yet, but it's a great workout if you can fit in the space for it!
paulk is offline
post #7 of 8 Old 03-25-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
having driven diesel trucks for a living.. I could not imagine handstarting a diesel... the high compression and heavy flywheel would really do wonders for upper body strength
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #8 of 8 Old 03-26-2013
Moderator
Jeff_H's Avatar
Actually, hand starting a diesel is not all that bad as long as the engine has an easy to reach cooling water intake seacock and easy to reach compression relief levers, The key is to close the cooling water intake, and open the compression relief valves. The engine is pretty easy to spin up to speed, and then flip the compression relief valves down one at a time. As soon as the engine fires, open the cooling water seacock. I have started a a Buhk and a Yanmar that way. The only problem in most cases is that most engines no longer come with cranks.
By the same token, I would not want that to be my primary way of starting my engine.
Jeff_H is offline
Diesel Engine won't start NCShadowdragn Gear & Maintenance 14 10-31-2016 05:59 PM
Diesel won't start leogallant Diesel 11 08-13-2012 10:56 PM
Diesel Hand Crank backcreeksailor Gear & Maintenance 8 04-01-2009 07:44 PM
Hot engine won't start threeofakind Gear & Maintenance 10 08-12-2008 04:43 PM
can any Human hand start a Yanmar 2QM or 2GM? hertfordnc Gear & Maintenance 24 06-01-2008 06:05 PM
