Prop walk combined with wind - Page 2 - SailNet Community
post #11 of 17 Old 03-26-2013
Joesplace's Avatar
Re: Prop walk combined with wind
Use to have lots of problems with a left hand drive and two blade prop. Changed to right hand drive with a three blade prop = much more control! Now I can backup and have some control . . .
Joe
Joesplace is offline
post #12 of 17 Old 03-26-2013
I've found that with limited maneuvering room and having to back in, a breeze blowing hard from port to stbd combined with prop walk, can induce starboard rotation that can't be halted and prevents me from staying "straight" long enough to get into the slip.
So, since the outer piling that would ultimately be the stbd bow line was well-fendered and boat has a steel-capped horizontal rubrail, I was able to stick the stern in far enough to get that bow line onto a starboard aft quarter cleat, then use it as a backing spring line to straighten her out, while we then boathooked the port dock lines and brought her in straight with no tears.
Note the emphasis on "well-fendered, and good rubrail", don't back in without them...;-)
nolatom is online now
post #13 of 17 Old 03-26-2013
Asleep at the wheel
jimgo's Avatar
I went with a slip with a long side finger in part because I wanted to be able to pull in bow first. That should avoid most of the reasons for wanting to be in stern first (we'll loverlook the river, so a better view will be had from the stern).
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #14 of 17 Old 03-26-2013
jackdale's Avatar
Any problems departing? I usually find it easier to leave bow first. But stern first is usually a better view of the traffic in the fairway. It's all compromises, as in anything boating.
jackdale is offline
post #15 of 17 Old 03-27-2013
chucklesR's Avatar
Ambidextrous docking works too.
I can go in either way.
chucklesR is offline
post #16 of 17 Old 03-27-2013
Asleep at the wheel
jimgo's Avatar
That other mast looks familiar...
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #17 of 17 Old 03-27-2013
Try it in one of these with a big cross wind, single screw. Oh, my!!
Paul T
dabnis is offline
Prop Walk dstew General Discussion (sailing related) 10 01-25-2012 10:20 PM
Prop walk Barquito Sailboat Design and Construction 9 07-22-2011 12:58 PM
Prop Walk davidpm General Discussion (sailing related) 13 08-31-2010 12:49 PM
prop walk bkw Learning to Sail 19 09-01-2006 01:40 PM
Prop walk - Catalina 30 rmf1643 Learning to Sail 4 08-03-2001 12:01 AM
