Lead vs cast iron keels - Page 2 - SailNet Community
post #11 of 17 Old 03-29-2013
Bristol 45.5 - AiniA
Re: Lead vs cast iron keels
Originally Posted by benesailor View Post
I have a iron keel and have had some very minor corrosion issues. I would agree that you can get a lower center of gravity with the lead but, i would think that is also factored in during design regardless its iron or lead. I will say; my neighbors 40" columbia hit something in the NYS Barge Canal (looks like it was steel) and just shredded his lead keel!! He has a 2" gash. I would have had a scratch.
If you think about the physics involved, if you hit something the energy involved has to go somewhere. With a lead keel much of it goes into deformation which is a pretty easy fix. With an iron keel, most of the energy gets carried upward into the hull and is a good opportunity to test the integrity of the keel/hull joint.
Iron keels came into use because they were cheaper and this became even more of an issue as lead prices soared. Some builders offer lead as an extra-price option and it is significant. To me it would not be a deal breaker, but I would certainly prefer lead.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
post #12 of 17 Old 03-29-2013
I would definitely agree about iron be a drag issue vs a steel fin and lead bulb.
In a cruiser; does it matter that much?
No and that's why now on almost all modern mass production boats the bulbs are in iron. It only maters to someone that wants to maximize performance and only performance boats offer that, many times as an option. But I am only talking about the keels that now are the norm in Europe. On all cast (iron or lead) the difference can be considerable between the two, in drag and weight that also affects performance.
post #13 of 17 Old 06-08-2015
Where do you get depleted uranium cores? From ATI2D
ATI2D is offline
post #14 of 17 Old 06-08-2015
Senior Moment Member
SloopJonB's Avatar
You don't
SloopJonB is offline
post #15 of 17 Old 06-09-2015
If you really want to go dense get some osmium. It's about twice as dense as lead.
Greg
Stumble is offline
post #16 of 17 Old 06-09-2015
Cruising at a snail pace
you want dense you need to use a lot of forum brain matter
Don't blow air up my rear, be useful and blow it at the sails!
Don0190 is offline
post #17 of 17 Old 06-09-2015
A compromised (showing signs of internal corrosion)iron keeled vessel will be hard to re-sell..
aa3jy is offline
Cast Iron Keel neoxaero Gear & Maintenance 7 11-30-2010 03:30 PM
Cast Iron Cookware turfguy Provisioning 36 12-17-2008 08:25 PM
opinions re: epoxy vs. plastic hulls, lead vs. iron keels ArgleBargle Sailboat Design and Construction 33 08-12-2008 10:21 AM
Iron Keels Versus Lead Keels twofish81 Gear & Maintenance 14 12-02-2007 01:58 PM
Iron Keels Versus Lead Keels twofish81 Sailboat Design and Construction 4 11-30-2007 10:55 AM
