Lead vs cast iron keels - SailNet Community
post #1 of 17 Old 03-29-2013 Thread Starter
Gregrosine's Avatar
Any opinions on the advantages of lead vs cast iron keels? With the additional mass of lead will a lead keel give a better ride than a cast iron keel?
Gregrosine is offline
post #2 of 17 Old 03-29-2013
jsaronson's Avatar
Re: Lead vs cast iron keels
lead will give you a lower center of gravity than a cast keel of the same size. Alos, no corrosion issues. Lead is WAY more expensive!
jsaronson is offline
post #3 of 17 Old 03-29-2013
Junior member, rest old
msmith10's Avatar
Yard guys also claim lead absorbs a grounding without transmitting as much force to the hull. I think there's truth to that in small or moderate hits. Of course, hitting a rock a 6+ knots with either isn't going to have a good outcome.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #4 of 17 Old 03-29-2013
night0wl's Avatar
From what i understand, the only advantage Iron has over Lead is that it tend to have better adhesion to epoxies and bottom paints. Get lead if you can.
S/V Jendai
Beneteau 343
night0wl is offline
post #5 of 17 Old 03-29-2013
On modern keels that is not very meaningful. They are made of steel for the foil and iron or lead for the bulb. The difference on the CG is not significant. What is significant is the size of the bulb and the associated drag.
Considering the same boat the one with a lead bulb will be slightly faster than the one with a iron bulb but the difference is much lesser regarding the time where the keels where all cast Iron or cast lead. There you would be right regarding the considerably lower CG on a lead keel. To compensate that the Iron keel would not only be bigger (more volume) but also heavier.
That would count negatively on the boat performance on two counts: Drag and weight.
post #6 of 17 Old 03-29-2013
I have a iron keel and have had some very minor corrosion issues. I would agree that you can get a lower center of gravity with the lead but, i would think that is also factored in during design regardless its iron or lead. I will say; my neighbors 40" columbia hit something in the NYS Barge Canal (looks like it was steel) and just shredded his lead keel!! He has a 2" gash. I would have had a scratch.
I would say that the maintenance issues with a iron keel are way overrated.(mines 20 yrs old, in florida salt) If it did start to rust out it would take 20 years to corrode off its so thick. Now, the amount of give VS a iron keel? I don't know. I would assume they would be about the same if you hit a rock. I would hope a lead keel wouldn't fall off or "give". Not well versed in this department.
I would think that having a bolt on iron keel may actually present fewer maintenance problems. No "smile" or separation issues between GRP and lead to worry about. It is one solid component.
I used to think nothing but lead; i have changed my mind. I have actually read some modern designers prefer iron for it's durability. Please don't ask me to find that. It's in one of my books.
This is a long ongoing debate. Then again, what do they use in a Oyster, Morris, Passport, Discovery, Swan? Lead
benesailor is offline
post #7 of 17 Old 03-29-2013
I would definitely agree about iron be a drag issue vs a steel fin and lead bulb.
In a cruiser; does it matter that much?
post #8 of 17 Old 03-29-2013
msmith10's Avatar
Agree with Benesailor. Iron keel wouldn't be a deal breaker for me.
Mark Smith
msmith10 is offline
post #9 of 17 Old 03-29-2013
MarkofSeaLife's Avatar
Dock
The price difference is pretty large, something like $2,000 per unit.
Anyway, if Oyster uses them then they are good enough for my boat.
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
post #10 of 17 Old 03-29-2013
Senior Moment Member
SloopJonB's Avatar
Bill Garden said the opposite - iron bounces off while lead "forms" around rocks & such. I've seen boats with iron bounce off and keep going but every lead keel I've seen hit came to a dead stop. Those observations would seem to back up Garden.
Iron keels also have the advantage of having removable and replaceable keel bolts whereas lead keels must have radical surgery or be re-cast to replace corroded bolts.
Properly coated iron keels do not present much, if any problem re: corrosion.
As far as performance, lead is unquestionably best, except for depleted uranium.
SloopJonB is online now
Cast Iron Keel neoxaero Gear & Maintenance 7 11-30-2010 03:30 PM
Cast Iron Cookware turfguy Provisioning 36 12-17-2008 08:25 PM
opinions re: epoxy vs. plastic hulls, lead vs. iron keels ArgleBargle Sailboat Design and Construction 33 08-12-2008 10:21 AM
Iron Keels Versus Lead Keels twofish81 Gear & Maintenance 14 12-02-2007 01:58 PM
Iron Keels Versus Lead Keels twofish81 Sailboat Design and Construction 4 11-30-2007 10:55 AM
