Wind indicator NOT for mast top - Page 4 - SailNet Community
 15Likes
post #31 of 48 Old 03-29-2013
KNOT KNOWN
Capt.aaron's Avatar
Re: Wind indicator NOT for mast top
Have'nt been up there for 2 years. I seem to remember someone saying something. I prefer that end of the lake for some reason.
" Some are boat wise and some are other wise"
Capt.aaron is offline
post #32 of 48 Old 03-30-2013
s/v Ilya
arknoah's Avatar
Originally Posted by Sabreman View Post
1. Tell-tales on a sail don't tell you where the wind is coming from. They show you the airflow over the sail and whether the sail is trimmed correctly for your course. Nothing more.
That's what I thought. Maybe I'm not sophisticated enough to use just the tall-tales, but I prefer to have both those and the Windex. One tells me the general origin of the wind, and the other lets me know when the sail is trimmed properly. I wouldn't be able to use only one and do as well as I should -- at least not with my current level of skill.
Sabreman and SloopJonB like this.
Ilya's Adventures:
____________________________
And straight on 'til morning
arknoah is offline
post #33 of 48 Old 03-30-2013
One
Always tired
If it's not about constant checking on your sails, but rather an intermittent, and general check, perhaps a Kestrel windmeter (handheld) might be the right choice. Some of those have wind direction too (I believe those models uses an ultrasonic sensor for direction).
They're far from cheap, though.
One is offline
post #34 of 48 Old 03-30-2013
KNOT KNOWN
Capt.aaron's Avatar
Spiting into the wind is free, and it will give you a good idea of how fast it's blow'n as well. Pi$$ 'n in the wind is also free, great visual on directon and force.
post #35 of 48 Old 03-30-2013
One
Always tired
LOL, true. I use my own windmeter when I'm going rowing (coastal/open water rowing), and just thought I'd put it out there as yet another option.
One is offline
post #36 of 48 Old 03-30-2013
Senior Moment Member
SloopJonB's Avatar
No-one can without tell-tales. When aerodynamic engineers are wind tunnel testing cars they cover them with tell-tale tufts to illustrate the flow over the model. They also use smoke generators to help the same way but we don't have that option on boats.
SloopJonB is offline
post #37 of 48 Old 03-30-2013
Over Hill Sailing Club
smurphny's Avatar
Telltales really let you know how the wind is flowing over the sails before any backwinding or turbulence is apparent in the fabric of the sail itself. When using a 150%+ genny, being able to see windflow and what the interaction is between main and genny is very helpful to get the sails working up to their potential. It's amazing how much difference becomes apparent in small adjustments of cunningham, outhaul, downhaul, twist, and sheeting angles. Just a small adjustment in jib tension/angle often gets rid of a lot of turbulence that you might not notice without telltales.
SloopJonB likes this.
smurphny is offline
post #38 of 48 Old 03-30-2013
KNOT KNOWN
Capt.aaron's Avatar
I guess I'm a sloppy lazy sailor. I get my sails trimmed by looking at their shape, my angle of list, and my seed. If I'm moving along at good clip, bone in my teeth, I'm happy. Never really paid too much attention to the riibons.
post #39 of 48 Old 03-30-2013
smurphny's Avatar
I guess I became hooked on telltales when I had my Lightning. They are great little boats for learning about sail tuning because you can really see and feel the results of sail adjustments more-so than on a heavy displacement boat. Aaron, you ever run into a guy named Pete Pedersen. He's an old buddy who now lives down your way, has a 40' Blackfin out of Cudjo.
smurphny is offline
post #40 of 48 Old 03-30-2013
SloopJonB's Avatar
You need to ratchet up your level of OCD. When the wind is as consistently light as it is here in the summer, you look for every bit of performance you can get.
looking for 1970's triangular wind indicator CC386 Gear & Maintenance 5 08-15-2011 02:02 PM
Autohelm Wind indicator help TIKI TIME Gear & Maintenance 5 08-01-2010 11:51 AM
Electronic wind direction indicator countrygent5201 Gear & Maintenance 2 11-24-2009 10:13 AM
WANTED KENYON or other, analog apparent wind indicator RobertLangDirect Electronics 0 07-20-2009 01:19 PM
Alas, poor Wind Indicator! SEMIJim Gear & Maintenance 20 04-01-2008 03:11 PM
