Wind indicator NOT for mast top - SailNet Community
 15Likes
post #1 of 48 Old 03-29-2013 Thread Starter
On my O'day 27 i do not have a wind indicator and i'm planning to get one but i just don't want the trouble to install it on mast top.
I'm not racing, so i just want something simple affordable trouble-less.
I saw a couple of things that look OK :
1) Wind-Tels from Davis (shroud mounted)
2) Sailsteady (this is deck-mounted, flexible, mostly for lasers but i was wondering if it would be OK also for a bigger boat). Practical Sailor magazine talks a bit about it in the last issue.
Any recommendatation?
many thanks
claudino is offline
post #2 of 48 Old 03-29-2013
Re: Wind indicator NOT for mast top
Dig into an old closet or basement and find an old cassette tape.. Break it open and you'll have a lifetime supply of telltales you can tie on anywhere you like.. Shrouds and back stay works well.
tspooner and Capt.aaron like this.
Faster is online now
post #3 of 48 Old 03-29-2013
chucklesR's Avatar
Mast top is best for undisturbed air.
Anything else is a compromise, as PS explains.
The sailsteady looks good for it's purpose, but tell tales, an ensign off the stern and many other things do just as well, look better and are less expensive.
chucklesR is offline
post #4 of 48 Old 03-29-2013 Thread Starter
I like that and I thought about that, but how do tape compare with the other indicators i mentioned ? If really not much difference, i'll go with your advice.
The only problem.... i don't think i have any cassette tape anymore...
claudino is offline
post #5 of 48 Old 03-29-2013
s/v Ilya
arknoah's Avatar
Hey, Iíve been around long enough that I could probably find a couple of 8-track tapes to pull apart to do this!
I tried the Wind-Tels product on our Macgregor 25 and I wasnít happy with them. Mounting them wasnít as easy as it should have been and as I recall, the indicators pointed to where the wind was going, rather than where it was coming from as in the case of mast mounted indicators. (Might not be right about this.) They were just confusing. Last year, we got a traditional mast mounted Windex, and Iíve been much happier with it.
As for the Sailsteady, Iím not sure where you could install it on the deck of a larger boat that might not be in the way, yet still work effectively.
Ilya's Adventures:
____________________________
And straight on 'til morning
arknoah is offline
post #6 of 48 Old 03-29-2013
MarkofSeaLife's Avatar
Dock
I wouldn't go a marine one at all.
When I was in the USA the Walmart had a series of weather displays. I bought one with a barometric recorder.. Ok it only records for 24 hours... But the unit is fine, works well, has good reception to the remote sensor etc.
So if I was looking for wind speed and direction without the marine BS prices I would have a look at their range
AcuRite Professional Digital Weather Center with Forecast / Temperature / Humidity / Wind Speed & Direction / Rainfall with AcuLink Remote Monitoring 01050C
Strap it to the stern rail. It won't be as acurate as mast top, but you will get to understand the offset for direction from mainsail draft etc.
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
post #7 of 48 Old 03-29-2013 Thread Starter
Yes, i saw some reviews mentioning the Wind-Tels installation is not as smooth as thought. For the direction, as long as it's understood how it works, it should not be an issue though.
On the Sailsteady i have the same concern.
claudino is offline
post #8 of 48 Old 03-29-2013
Sabreman's Avatar
Shroud tell-tales, whether cassette tape or the commercial variety are a poor indicator of wind direction. As chuckles says, there is (mostly) undisturbed air at the top of the mast. This fact should not be dismissed lightly, air on the shrouds is affected by both the ground effect, hull configuration, mast, main, jib and will be inaccurate by may degrees (can be 10+). There is a reason why competitive boats put a windex up top. To be direct, if accuracy isn't an issue, then why bother at all? Just turn your head until the wind sound is equal in each ear - you nose will be pointed into the wind.
To install a Windex on the masthead is a 15 minute job, at most.
msmith10 likes this.
Sabre 38 "Victoria"
Sabreman is offline
post #9 of 48 Old 03-29-2013
Asleep at the wheel
jimgo's Avatar
As long as you either have a deck-stepped mast or are OK with going for a ride up the mast (and have someone to help you).
I've thought about a Windex; I'd really like one. But my wife is scared to haul me up, and won't let me haul her or the boys up. She keeps saying something about 7 and 5 year olds not being able to actually do the work. But, anyway... Of course, you COULD pay a yard to do it for you, but then you're easily doubling your costs.
Yeah, I know, everything on a boat is a compromise...
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #10 of 48 Old 03-29-2013
Senior Moment Member
SloopJonB's Avatar
IMHO after a compass a Windex is the single most valuable instrument you can have on board. It's the cheapest as well.
Go to the trouble to install one, you won't regret it. Telltales on the sails & rigging help a lot too but the Windex is more important.
Sabreman, MedSailor and smurphny like this.
SloopJonB is offline
looking for 1970's triangular wind indicator CC386 Gear & Maintenance 5 08-15-2011 03:02 PM
Autohelm Wind indicator help TIKI TIME Gear & Maintenance 5 08-01-2010 12:51 PM
Electronic wind direction indicator countrygent5201 Gear & Maintenance 2 11-24-2009 11:13 AM
WANTED KENYON or other, analog apparent wind indicator RobertLangDirect Electronics 0 07-20-2009 02:19 PM
Alas, poor Wind Indicator! SEMIJim Gear & Maintenance 20 04-01-2008 04:11 PM
