26 feet long and at 4 tons - SailNet Community
post #1 of 8 Old 03-29-2013 Thread Starter
Have a go and DIY .....
My yacht is 26 feet long and weighs approx four tons
how long should the anchor chain be. plus rope .
Or No anchor rope. ?
What length of anchor chain would the members recomend I should use.
macwester26 is offline
post #2 of 8 Old 03-29-2013
Gin Swilling Yacht Monkey
Re: 26 feet long and at 4 tons
The length of the anchor chain and/or rope depends more on the depth you are anchoring in than on the weight of the boat, I think... you want to have adequate scope.
groggy is offline
post #3 of 8 Old 03-29-2013
I would say chain at least 3X's the length of your boat and 200' (maybe 250) of rope rode would do it.
so... 75' chain, 200' rope rode and the biggest/heaviest anchor your boat can handle on the front end. I think a 40-45 lb delta type would hold you thru most anything.
If you are anchoring around the Caribbean, nothing but chain.
You can go to any of the Anchor sellers and they will recommend a size.
The best advice i've heard is " If your boat is dragging; then your anchor isn't big enough"
benesailor is offline
post #4 of 8 Old 03-29-2013
S/V Lilo, Islander 32
Agreed, depends on where you are anchoring, how deep it is will determine the total length, and whats on the bottom will determine if you can use rope or not. I like rope with some chain myself, as I don't have an electric (or manual) windlass, so I am the windlass
EDIT: Amount of chain can vary too, depending on your usage. If you just over-nighting on weekends in good weather, and in your marina if it's not so good, I've heard 1 boat length as a good recommendation. benesailor says 3x, sounds good if your traveling farther from home and might be out in worse conditions, but that might be heavy to lift if you have to lift by hand.
Size will be determined by boat size and weight, but I can't speak to that directly, nor do I know what anchorages are like in the Northeast, so I guess I'm not much help
S/V Lilo
1964 Islander 32
Saint Helens, OR
IslanderGuy is offline
post #5 of 8 Old 03-29-2013
mac
Depending on where your sailing grounds are "northeast England", Hull to Berwick on Tweed with a tidal range of at least 6m (20ft) and some inlets that drain to a mud bottom and very few rocky bottoms you could probably get away with 5 or 10 ft of chain and about 200ft of rope rode. Ask what most boaters use in your area.
More rocky bottoms north of Firth of Forth and different strategy, also smarter to use a harbour.
Anchoring off shore in the northsea is just not going to happen so plan for the inlets and estuaries.
North of Berwick, or Holy Island will be more rock and sand bottoms, still a few mud inlets, but more than likely rocky/weed bottom at low tide, if not in a harbour and tied to a wall.
1970 Havsfidra 20 by Fisksatra
On the Delaware River at Fox Grove Marina Essington PA
Ulladh is offline
post #6 of 8 Old 03-29-2013
Dirt Free
boatpoker's Avatar
Almost 9000lbs. is an extremely heavy boat for 26'. What is it ?
Be the man Sharon thinks I am - wg
I can do that
- wg
Be the master of your own disaster - wg
If you're not laughing, you're not doing it right. - wg
if you can live with the consequences, go for it. - wg
I yam what I yam an' thats all that I yam. - Popeye
boatpoker is offline
post #7 of 8 Old 03-30-2013
no longer reading SailNet
Alex W's Avatar
I imagine it is a Macwester 26 based on his forum name. However sailboatdata says the dry weight on one of those is 6700lbs. I don't know where the extra 2000lbs comes from.
Ask around at your local marinas and stores for anchor recommendations. You need length for depth. I have a little bit bigger boat in the Puget Sound and use a 25lb Manson Supreme anchor, 300' of 1/2" and 30' of 5/16" chain. That lets me safely anchor in water up to about 40', or push it and anchor in water up to about 55' deep. My secondary rode has the same amount of chain, but 200' of rode.
I could probably stand to have a little more chain.
Alex W is offline
post #8 of 8 Old 03-30-2013 Thread Starter
Dry weight as you said and with a tiny Vire engine fitted.
Now larger and heaver engine extended keels and Skeg.
Larger fuel tank Anchor chain sailing Kit and sails.
Gearbox Shaft and prop all upgraded to Larger.
The weight starts to add up..Most timber work replaced with G.R.P.
and not made for lightness.....
Even the new portholes weigh an additional 9 lb.
P30 Gross Tons nickmerc P30 1 10-09-2015 09:52 PM
Tons of tsunami debris in the Pasific Jon Amtrup News Feeds 1 10-25-2011 11:28 AM
IYT/MCA 200 tons sail unlimited Cpt. available JulleGylling Crew Wanted/Available 0 11-19-2009 10:05 AM
Tons of questions PARUS Introduce Yourself 1 09-14-2008 04:30 PM
Displacement: the 2.5 to 5 tons per person rule deckhanddave General Discussion (sailing related) 5 11-10-2006 02:32 PM
