Increasing flotation - SailNet Community
 5Likes
post #1 of 26 Old 03-29-2013 Thread Starter
I have a Neptune 24 made by Capital Yachts. My problem is that it rides really low in the rear and I would like to add some flotation to address this problem. My outboard is a Honda 8HP, so no excess weight there, and I have moved the batteries from their original location more forward to help. Is two part foam the best/only option to not lose any stowage? Do I need to cut open my liner to access the voids between? Any insight would be very helpful. Thanks.
mattnj is offline
post #2 of 26 Old 03-29-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
Re: Increasing flotation
you are saying she rides low.. so she is not riding on her lines?
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #3 of 26 Old 03-29-2013
Irunbird's Avatar
You're outboard really could be a major part of the problem. I know an 8 hp might not exacly be light, but could you take that off the mount and stow it below deck somewhere near the mast (assuming it's keel stepped)? My boat is similar displacement (maybe 400 lbs heavier) and we cruise with our 6 hp outboard on the transom, but would never consider racing that way-- it's significantly faster stored below. I don't see how it's possible to add foam anywhere (inside the hull) to alter the way the boat sits on her lines- you just have to move weight forward.
Irunbird is offline
post #4 of 26 Old 03-29-2013
Master Mariner
capta's Avatar
I don't believe floatation inside the hull would do anything to solve your problem. If you wanted to spend a small to mid-sized fortune in changing the boat to solve the problem, then you might try "micro-ballons" which are used by many racing boats to slightly alter trim and sailing characteristics.
A much cheaper and easier way to solve your problem might be to shift things around inside the boat (add an anchor and chain forward, stow heavier items forward; lighter stuff aft, etc.) until you have achieved the trim you desire.
facebook.com/svskippingstone
Our Videos;
capta is offline
post #5 of 26 Old 03-29-2013
Foam heavier than air, fill voids (air) with foam to add floatation, I'm not seeing it.
capttb is offline
post #6 of 26 Old 03-29-2013
Junior member, rest old
msmith10's Avatar
Capta is correct in saying that adding foam inside won't alter the lines, in fact it would actually worsen it by adding more weight in the area where you actually want more displacement. Move weight forward .
jameswilson29 likes this.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #7 of 26 Old 03-29-2013
The foam in all the aft compartments prevent you from stowing anything in them thereby trimming the vessel. It's all about method.
Capt Len is offline
post #8 of 26 Old 03-30-2013 Thread Starter
She rides below the water line in the stern. The boat has done this since new and is common with the Neptune's.
mattnj is offline
post #9 of 26 Old 03-30-2013 Thread Starter
The boat is rated for a heavier outboard. It gets really pronounced when I have several crew in the cockpit. I moved my batteries forward, my water tank is in the bow, my head and holding tank, an oversized anchor, and a hundred feet of chain.
mattnj is offline
post #10 of 26 Old 03-30-2013
One of None
deniseO30's Avatar
Don't motor so fast. Sail more. I think you WILL notice a difference! Displacement hulls drop lower in the stern when being pushed near hull speed.
4 adults in the cockpit are an easy 600 + lbs!
Flotation cannot be increased without making the boat larger; the only way is to make it lighter.
My last project!
deniseO30 is offline
Increasing purchase on cunningham and outhaul. zz4gta Gear & Maintenance 14 03-03-2009 10:09 AM
Thoughts on increasing the furling line size? labatt Gear & Maintenance 26 11-06-2008 07:52 AM
Winds 15 To 25 Mph. Gusts Up To 35 Mph...increasing To 45 Mph NewsReader Mass Bay Sailors 0 02-04-2007 05:15 PM
Increasing Sail Area dm567 General Discussion (sailing related) 33 01-18-2007 10:52 PM
Increasing the pace on Leg 5 @ Sail World Australia NewsReader News Feeds 0 04-10-2006 03:16 AM
