Yamar 2gm not winterize - SailNet Community
post #1 of 6 Old 04-01-2013 Thread Starter
Hello I check on my boat this weekend , and it appear to me the boat yard ,
did not winterize my engine , or head .
I am most concern about motor . I did not see any red in sea strainer .
What should i look for ( Ice damage ) , and what precautions should i take,
before trying to start motor .
thank you
windtrip290 is offline
post #2 of 6 Old 04-01-2013
Re: Yamar 2gm not winterize
Interesting..did you pay for winterization? Do you have a contract stating that this service was to be performed? Where are you located and how was your winter(prolonged freezing)?
Before any attempt I'd have a marina have a rep present before starting so they are aware of the situation. CYA
aa3jy is offline
post #3 of 6 Old 04-01-2013
Moderator
Jeff_H's Avatar
I would not panic until you talk to the boat yard. There are a number of possible explanations on why you don't see pink, which result from the different ways that your engine could be winterized. For example I personally do not use 'pink' antifreeze in the engine, using the yellow-green type since it is intended for dissimilar metals. Also I have had boats on which I would drain the strainer and intake hose after winterizing the engine itself since you could not reliably get antifreeze into them, and they would drain when you disconnected the downstream hose at the strainer.
I also completely agree with aa3jy that before you make any attempt to do anything, that you talk to the marina and have a marina rep present before starting so they are aware of the situation.
Jeff_H is offline
post #4 of 6 Old 04-01-2013
chucklesR's Avatar
Agree with the above -
You don't need anti-freeze in the strainer, simply draining the water out is sufficient to prevent damage. Ice damages because frozen water displaces more area that liquid water which causes pressure and breaks stuff.
Same thing on the plumbing, a drained system is just as safe as a antifreeze filled system. Folks selling winterization services don't want to admit that, but think it through a bit.
chucklesR is offline
post #5 of 6 Old 04-02-2013
NON member
AE28's Avatar
Agree with Jeff (and others)…
What did you contract with the yard to do?
Then talk with the yard and find out what they did and how they did it.
You may be AOK.
If not, then go to the “next step”.
AE28 is offline
post #6 of 6 Old 04-02-2013
Learning the HARD way...
eherlihy's Avatar
Frequently, the winterization process is completed with compressed air, and not antifreeze. That would explain the lack of pink.
Check with the yard manager to see if your boat was winterized, and let him know that you would like him present when you fire her up.
eherlihy is offline
your favorite way to winterize? Kiltmadoc C & C 2 10-12-2011 05:13 PM
when to winterize rosskowh Gear & Maintenance 8 01-11-2010 08:23 AM
partial winterize QuickMick Gear & Maintenance 3 12-15-2009 10:11 AM
have to winterize? xluke Gear & Maintenance 1 10-28-2008 01:59 AM
Do I nee to winterize? mathislaw1 Gear & Maintenance 26 03-13-2007 09:28 AM
