Moody 41 AC has no traditional traveler? - SailNet Community
 3Likes
post #1 of 18 Old 04-01-2013 Thread Starter
美国华人, 帆船 教授及输送
http://www.moodyboats.com/#/gb/nc/mo....html?type=666
Please look at the above link and click on "Aft Cabin 41 tab" What kind of main sheeting system use in here? It seems there are many new boats do without the traditional traveler. Not sure how one can trim the main to the proper shape?
What is the Pros and Cons. TIA.
Fine Print:
I am old school. Integrity is to do the right thing even when no one is watching.
rockDAWG is offline
post #2 of 18 Old 04-01-2013
Re: Moody 41 AC has no traditional traveler?
Seems from the picture that it's some kind of double ended sheeting system w/o a traveller. Sheets is run to the cabin top winches?
Pros
-Cheaper (for the builders)
Cons
-must use the wang to control the height of the boom (sail shape)
Other boats I have seen have double main sheets.
Give better control of sail shape than above, but not better than a traveller.
My old boat has traveller in front of the companionway (same position as the Moody).
With German sheeting system going aft to the wheel and traveller adjustable from the wheel. Can't understand why the can't do similar on new boats?
rockDAWG likes this.
knuterikt is offline
post #3 of 18 Old 04-01-2013 Thread Starter
美国华人, 帆船 教授及输送
Thanks KK,
Just spoke with the dealer, he told me that the German Sheeting mounted on the coach roof is a factory option for $2,500. However, I have never used one, so not sure how that compares the traditional traveler??
Fine Print:
rockDAWG is offline
post #4 of 18 Old 04-01-2013
Thanks KK,
German sheeting on the coach roof for $2,500, is that a joke?
What is the standard main sheeting system?
A traditional German sheeting system with the ropes led aft has the benefit of being adjustable from both sides & close to wheel.
On coach roof I don't know..
post #5 of 18 Old 04-01-2013 Thread Starter
美国华人, 帆船 教授及输送
Yes, i feel the same way too, but that is what he said. I also have a copy of their optional list too.
I have not seen a German sheet on the coach roof either. I will clarify this more when I talk to him again.
Fine Print:
rockDAWG is offline
post #6 of 18 Old 04-01-2013
No, there is not any problem with it. Several boats offer that option and then you can control the boom from the wheel but, of course, that has nothing to do with having a traveler or not. That system that "dispenses" a traveler is used in many boats between them, Hanse and Bavaria. It is better than nothing but not as good as a big traveler.
Some cruisers have so small travelers (and some even on top of an arch) that I don't know if those have any advantage over this system.
That system, as well as all sort of travelers was already discussed in a thread sometime ago, if I remember right.
post #7 of 18 Old 04-01-2013
Assuming the standard main sheet arrangement is cabin top on one side.
The extra hardware would be one block at the boom + one block at the goose neck + one block at the mast + an extra clutch + extra rope and maybe an extra sheave in the deck organizer = 2500$
Not much extra work involved..
I can't see the point of this arrangement, if you need to go to the companionway to adjust the main sheet what do you gain from this.
I was to add all this hardware with this setup (w/o traveller) it would make more sense to have a two sheet system as Bavaria use on some never modells?
post #8 of 18 Old 04-01-2013
Maybe I am not following you but a German sheeting system is a two sheet system. I guess that is the system that Bavaria uses (I know they can have it as an option). Bavaria has a big advantage over the others: They offer standard or as an option (depending on models) 4 winches on the cockpit and that is very useful regarding using a German sheeting system. On many production boats you cannot have two extra winches on the cockpit, not even as an option.
post #9 of 18 Old 04-01-2013
A German sheeting system is a double ended system (or endless) not a two sheet system.
The original idea was to make it easy to adjust the sheet from both sides of the cockpit (read the high side).
Like this
I can't understand the reasoning for a German system using cabin top winches, as you would have to move into the center of the cockpit to adjust the sheet all the same.
If you have room for two crew you could have the benefit of using two winches during a gybe.
Also I think the price quoted is at bit steep, remember Hanse is not paying the same price for hardware as you and I.
Knut
post #10 of 18 Old 04-01-2013
sailortjk1's Avatar
When you press the dealer with the question, his likely response will be, "Nobody uses the traveler anymore." Just like the demise of a dedicated full chart table and navigation station, "Nobody uses them anymore."
I still use and find value in both of these concepts, I am sick and tired of hearing the standardized response, "Nobody uses it any more."
Courtney is My Hero
sailortjk1 is offline
Moody 42 BovaMarine Boat Review and Purchase Forum 0 03-29-2009 08:43 AM
Moody 41,419,422 metamorphster Boat Review and Purchase Forum 2 06-05-2008 10:37 AM
Moody 33 MK I kregar Boat Review and Purchase Forum 4 03-04-2008 12:08 PM
Moody 46? orthomartin Boat Review and Purchase Forum 3 02-20-2007 11:35 AM
Moody ericfremont Boat Review and Purchase Forum 2 10-31-2002 09:33 AM
