UK 220 volt spec to US 110 volt - SailNet Community
 7Likes
post #1 of 17 Old 04-01-2013 Thread Starter
美国华人, 帆船 教授及输送
How difficult converting the 220 v to 110 v system? It I understand correctly, it shouldn't be hard for a handy person, but I would like to check first.
1. Convert all AC receptacles
2. Reconfigure the convertor input voltage
3. Heat water heater (not sure if it runs in AC or not)
What did I miss?
Fine Print:
I am old school. Integrity is to do the right thing even when no one is watching.
rockDAWG is offline
post #2 of 17 Old 04-01-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
Re: UK 220 volt spec to US 110 volt
well.. first off it is 120, not 110. You also need to look at the Hertz. US power runs at a standard 60hertz. I have heard of some places in third world countres running as low as 15hz and some operating rooms running at 180 (to eleminate flicker in lighting)
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #3 of 17 Old 04-01-2013
Master Mariner
capta's Avatar
If you halve the voltage, you double the amperage. You might be getting into a complete rewire, especially if it's an older boat.
Omatako, SVAuspicious and jimgo like this.
facebook.com/svskippingstone
Our Videos;
capta is offline
post #4 of 17 Old 04-01-2013
depending on the wiring.. if it is in good shape, it should be ok.. but everything attached to it.. Switches, Outlets, anything hardwired to the system will need to be looked at or replaced.
I am also unsure on what standards they Use in the UK.. so black might not be hot, white/silver might not be neutral, and green might not be the earth.
Art Haberland
post #5 of 17 Old 04-01-2013
Omatako's Avatar
As Capta said the amperage in your systems goes up as the voltage comes down so at the very least you'll need to check that the wiring is of suitable gauge and that fusing is appropriate.
Simple calcualation is amps = watts / volts.
So a 1000 watt microwave as an example running on 220v will require a supply of 1000/220 amps which is about 4.5 amps.
The same microwave at 120v is 1000/120 which is about 8.3 amps
In my boat most circuits are capable of easily managing this type of amperage but because I know it doesn't bother me. If you also know then it probably won't bother you either.
FWIW, my boat is American so 120v and I live in new Zealand so domestic power is 220v but given that almost all my equipment runs on 12v I have left the 120v circuits as they are and run just 2 appliances via an inverter (microwave and hot water cylinder).
rockDAWG and SVAuspicious like this.
Arthur C. Clarke
Omatako is offline
post #6 of 17 Old 04-01-2013 Thread Starter
美国华人, 帆船 教授及输送
It is a 2008 Beneteau, built in France. I doubt they would use the undersize wires because of the higher voltage in UK. I also believe most the A/C systems may have a multi-voltage input set up.
I will look into this becasue it becomes a PITA headache.
Fine Print:
rockDAWG is offline
post #7 of 17 Old 04-01-2013 Thread Starter
美国华人, 帆船 教授及输送
When you have the shore power and use it to charge your battery, do you use a transformer to step down to 115, or you have switched your boat to take 220 directly ?
Fine Print:
rockDAWG is offline
post #8 of 17 Old 04-01-2013
tommays's Avatar
Well the high voltage allows you to use everything smaller from wire to switches
In simple terms the 220 volt European boat is using two (2) 120 volt phases with NO neutral circuit at more than likely 50 Hz
The 50hz VS 60 Hz is generally not a problem
And AMERICAN dock is going to be 120 volts suppled by (1) 120 volt phase and a neutral leg
Depending on how much stuff is on the boat it could be pretty simple OR pretty complex
We have a friend Lorenzo with a 50++ some odd foot Swan that has and electric room about one step simpler than a nuclear reactor
I am NOT doing and APRIL FOOLS this boat has every darn item possible with every possible complication like and older 50 Hz refrigeration unit
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #9 of 17 Old 04-02-2013
Omatako's Avatar
I never use shore power. I am to a large extent off-the-grid with high output alts and wind/solar passives so am self sufficient but I am not living aboard.
I have built a diesel genset that puts out 200 amps continuous for when we go off-shore long term.
Arthur C. Clarke
Omatako is offline
post #10 of 17 Old 04-02-2013
Omatako's Avatar
Whilst I am not an electric boffin, I do believe that some electric motors don't like wrong frequency supply and will let you know quite fast.
ottos likes this.
Arthur C. Clarke
Omatako is offline
Replacing 12 volt batteries with 6 volt justonemoreproject Electrical Systems 11 03-15-2012 10:13 PM
Mixing 6-volt and 12-volt Batteries? captainfrank Gear & Maintenance 3 11-08-2008 12:33 PM
12 volt to 24 volt conversion SMIK12 Gear & Maintenance 1 04-18-2005 02:50 PM
6 volt or 12 jbanta General Discussion (sailing related) 4 10-23-2003 02:12 PM
6 Volt Batteries vs 12 Volt ABullard Gear & Maintenance 10 09-06-2001 06:41 PM
