Sinking? - SailNet Community
 7Likes
post #1 of 17 Old 04-01-2013 Thread Starter
Master Mariner
capta's Avatar
Sinking?
Once again it has come to my attention that a vessel was lost due to an influx of water and insufficient pumping capability.
In this case I'm writing about the Bounty, (I just read; Life and Death on the Bounty) but just a few months ago a very good friend had his boat sink out from under him with both engines running full bore, heading for shallow water to beach the boat, almost costing him his life.
Bounty had two main engines and two 20 kw generators from what I understand. That's possibly four diesel engines running at full capacity and just exactly what is keeping those engines cool? Water!
If you ever find yourself in this situation, close the seacock (s) and take the intake hose (s) off the thru hull and drop it (them) in the bilge! There should be a sea strainer to catch debris which is very easy and quick to clean, unless you have sea chests, in which case a cloth or colander or even your fingers will minimize the clogging.
I'm not saying that in the case of the Bounty that it would have made a difference, but they may have had a better chance with less water in the engine room, and engines and generators running. It definitely would have made a difference (all the difference) in my friend's case.
On some boats I have even Y-ed the intake and carried enough hose to reach anywhere aboard.
Throwing a sail over a hole in the hull can give you enough time to get a mattress inside with something (a door, the table whatever) to push against the hole from the inside, further slowing the influx of water. Then, when the weather abates (if that's a problem) maybe you can arrange a more permanent solution and sail yourself back to safety.
Some friends of mine were holed by a log a thousand miles SW of Hawaii and after doing the above, sailed safely back to Honolulu, certainly not without problems, but again they lived AND saved the boat.
So in those unwanted moments of catastrophe, do not lose your head and your boat; think. There may be a simple, easy, if temporary, solution to your immediate problem.
Bob142 and woodyby like this.
facebook.com/svskippingstone
Our Videos;
capta is offline
post #2 of 17 Old 04-01-2013
bljones's Avatar
Re: Sinking?
twp issues with using an engine's coolant pump as a bilge pump on a big old wooden boat:
1. You gotta be able to pump it out faster than it is coming in, and cooling pumps aren;t designed to move a big GPM number..
2. Ever seen the bilge in an old working wooden boat? Just dropping the intake hose in the bilge is inviting the pump itself to get snuffed. Now you have no pumps and no power.
3. Being holed by a log on a smallish modern fiberglass boat is a whole different level of ass-pucker than trying to keep up with the square rig, constantly leaking hull , excessive windage and just generally being outmanned and outgunned circumstances of slamming through a widefront hurricane in a cumbersome, slow-moving, ill-maneuvering replica ship.
It's 5 o'clock somewhere:
bljones is offline
post #3 of 17 Old 04-02-2013
denverd0n's Avatar
Re: Sinking?
Like bljones said.
Think about how much water comes out when your engine is running. On most boats it is basically a very small stream--almost a trickle. Certainly not even close to as much as a large bilge pump can flow.
Then, what if you clog your engine intake with crap from the bilge? Now you are in REALLY big trouble. You've just made your problems several times worse.
Of course, in dire circumstances, you do what you have to do. But I would rather make sure that my engine keeps running, and therefore will still be able to power my electric bilge pumps. I would only use the engine coolant intake as a bilge pump in the most extreme of circumstances.
denverd0n is offline
post #4 of 17 Old 04-02-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
Re: Sinking?
there is a difference between the engine's waterpump and the raw water cooling (assuming your boat uses a split system)
IF you were to open the radiator on a car while it was cold and start the engine (I do not recommend doing this while the car is hot) you will see that the engine's waterpump can push a good amount of water. Maybe not as much as a good bilge pump, but it can.
The only reason the engine on a boat seems to move so little water is due to restrictors in the cooling intake. Unlike a car that has an air to water radiator (an inefficent design) that can see temps from -40 to well over a 100 ambiant.. a boat's cooling system typically only sees it's ambiant temps from around freezing to the upper 80s.. so you have to restrict the amount of water incoming to keep the engine from running TOO cool
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #5 of 17 Old 04-02-2013
Re: Sinking?
There are some threads on SN that did the math on the volume of water that would come through fairly small holes. The size hole that a raw water pump could keep up with, probably wouldn't scare you that much. Put a pillow on it and your foot against it.
SVAuspicious likes this.
Jeanneau 54DS
Minnewaska is offline
post #6 of 17 Old 04-03-2013
Send a message via Yahoo to dacap06
Re: Sinking?
I think the best thing you have to keep your boat from sinking is good plan and the stuff at hand to implement it.
The first part of my plan is having damage control gear on board. The point of damage control is not to repair but to slow the leak enough that your pumps can keep up until you can get the boat out of the water. (Thanks for all that training, USN!) Needless to say it works better on small boats that are coastal cruising or in protected waters than it does for blue water sailing.
We all have hammers and the wood plugs for seacocks, of course. For other holes, I bought one of those foam cones to stuff in them, If you can get to the leak and it is big, stuff anything at hand into it that fits -- T-shirts or underwear, your kid's pool weenie cut to size, whatever. I like foam stuff that you can compress then it expands to fit the hole. That works even for irregular hole shapes.
I have Rescue Tape to wrap around leaking fittings, hoses, and such.
I have a tarp with pre-rigged lines I can pull up tight against the hull to cover cracks or whatnot that the foam cone can't handle. Note to self -- don't cover engine cooling water intake (which means you have to know where it is) unless you absolutely have to! A tarp won't work near the keel since you can't pull it up tight against the hull, but it would slow a leak in the forward or aft part of the boat. I've debated keeping some butyl tape I could stuff in the crack before tarping it. I'm not sure how effective it would be without something to hold it in place (like the tarp, maybe).
Now the second part of my plan is thinking through how to find the leak quickly. It may not be obvious, so I will look at sea cocks and through hulls first, then hose clamps, then the hoses themselves. Of course, if you experienced a precipitating event you probably know the general area to search. If not, start at the bottom and work up (cause it is harder to figure it out underwater, and the water level starts on the bottom and rises).
Once you have the damage under control, you can see whether it is repairable at sea or whether you need to make a run for shore and the nearest travel lift.
So what do you do once the awful day comes?
1) Call the Coast Guard and let them know of your situation.
2) Get the damage under control. If you can't, get your ditch bag.
4) If you can, assess what's next -- repair, Towboat US, limp back home, Coast Guard, etc.
5) Call the Coast Guard again and update them.
6) Once you (and, one hopes, the boat) are back on terra firma, break out the boat bucks.
So that's my plan. What's yours?
Tom
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
dacap06 is offline
post #7 of 17 Old 04-03-2013
chucklesR's Avatar
Re: Sinking?
One inch hole, 4 feet below water line = 40 gallons per MINUTE (2400 per hour)
(a through hull) or small log
2 inch hole, 2 feet below water line = 111 gallons per minute
(a rudder stock, or bigger log)
Chart for Determining Flow of Water Through Holes in Gallons Per Minute
Add the additional depth below water line that weight of water will cause, it becomes a losing battle quickly.
Your time (what little you have) is better spent stopping of reducing the flow - not disconnecting engine hoses and leading them to the bilge.
The Navy teaches it that way - stop influx, then de-water.
Perhaps sailors should pay attention to that experience?
The average sailboat carries perhaps a pair of 2000 gallon per hour pumps - which really with head, curved leads and such can pump 1500 GPH if said water is where the pump intake is (and from reading Practical Sailor reviews that 1500 is optimistic as all get out).
Installed, operating bilge pumps can buy time but unless you stop the influx that's it.
Consider a rudder stock fail and fall out - 111 gallons 850 plus pounds added in 60 seconds to the stern of the boat - think that water is conveniently flowing to the center and pumped out? Not likely, and every second adds more angle down at the stern.
Ditto the log strike at the bow, and add the extra water influx because you were moving forward. Can you get to your hull at the bow (under v berth, anchor locker etc) and plug a odd shaped ripped up hole while water is rushing in and you are upside down, in the dark?
It's about risk management, it's also about percentages
Planning, pre-positioning, preparing and practice and all the other P words and a few others.
chucklesR is offline
post #8 of 17 Old 04-03-2013
MarkofSeaLife's Avatar
Dock
Re: Sinking?
Agree with that.
Also I don't like the idea of tampering with the thing that's providing the electricity to the real pumps and the emergency communications.
However, if a long way from shore and all influx reduction ideas have reduced it as much as possible and you would otherwise be sitting on your butt, then doing the raw water intake may be an idea....
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
post #9 of 17 Old 04-03-2013
Mermaid Hunter
SVAuspicious's Avatar
Re: Sinking?
This old chestnut comes up all too often. It is itself a safety hazard.
Raw water pumps for diesel engines are generally sized at 15 gpm / 100 hp. If you have a 40ish foot boat with the ubiquitous Yanmar 4JH4E or similar the raw water pump will move about 8 gpm. I was surprised it was that high so I stuck a bucket at the exhaust outlet on my boat and it's pretty close. 8 gpm is less than 500 gph. Now run down to West Marine and price 2000 gph bilge pumps. Buy a couple. Spec the nice big Whale manual pumps and buy one of those also. Don't fuss with the engine cooling system.
If you really want to move some water get a trash pump from some place like Northern or Harbor Freight. You can run a trash pump as a direct drive off the engine (or shaft) or with an electric motor powered by a generator. Honda sells an outstanding gasoline powered pump that is the size of a canister vacuum cleaner.
Having participated in the development of US Navy damage control books I strongly agree that the priority is to stop the influx of water.
SVAuspicious is offline
post #10 of 17 Old 04-03-2013
Re: Sinking?
I had to bookmark that for when this discussion inevitably comes up again. I completely understand how using the raw water pumps seems logical, until you compare the flow rates to actual ingress rates.
Seems it would take something like a quarter inch hole pretty close to the water line for the typical raw water pump to keep up. I can't see panicking over that. Shove a pillow over it and deal with it. Better yet, heel the boat over in the other direction and you'll have all day to deal with it.
Here was a thread I started a couple of months ago to see what people had aboard. I was a bit surprised it died an early death with only a couple dozen replies.
Emergency leak repair
Jeanneau 54DS
Sinking davidpm Seamanship & Navigation 22 04-10-2011 04:17 PM
Sinking RXBOT General Discussion (sailing related) 88 11-06-2008 03:14 PM
We're Sinking! jhulmer Seamanship & Navigation 32 11-05-2007 09:33 PM
Sinking Dink in tow Rogerdshoemaker General Discussion (sailing related) 1 10-30-2006 05:37 PM
Help! We're Sinking! Don Casey Seamanship Articles 0 03-21-2002 07:00 PM
