Apparently I'm not meant to have a boat... - Page 19 - SailNet Community
 228Likes
post #181 of 455 Old 05-14-2013 Thread Starter
Asleep at the wheel
jimgo's Avatar
Re: Apparently I'm not meant to have a boat...
OK, so at least it spins and you know it isn't jammed; that's a good start. So spinning the engine output side and holding the lever in place doesn't let you go into forward, but it does let you go into reverse? That's strange.
Have you rebuilt your transmission before? I read that for the Hurth/ZF transmissions, it isn't worth the trouble. You'll wind up replacing the transmission in a few years anyway.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #182 of 455 Old 05-14-2013 Thread Starter
Asleep at the wheel
jimgo's Avatar
BTW, I'm not THAT far from you. If/when you decide to pull the transmission, let me know. If I'm free I'll come lend a hand. I'm not incredibly strong, nor am I all that mechanically inclined, but I can follow directions.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #183 of 455 Old 05-15-2013
One of None
deniseO30's Avatar
Jim thank you for the offer to help! I'll let you know what an when if it's going to happen. I've not done such a rebuild, but the guys in my club have pulled them and did flex plate and and dipstick repairs. My research is looking at the ZF6 which is the new version of the old and they have not really changed much at all. They are supposed to be pretty easy to rebuild as far as complicated goes. I just don't know what to do since I can't find 12-1800 for a new or rebuilt one. We have a boom truck, here too.
My last project!
deniseO30 is offline
post #184 of 455 Old 05-15-2013
chucklesR's Avatar
Denise, I'm assuming you have directly observed that the cable does push the lever into forward (all the way) and have diagnosed the problem as internal to the transmission?
The lever operates a hydraulic valve inside the transmission - where rebuild gets expensive.
The valve works or you would not get reverse.
Occam's razor (simplest solution) says that it worked last year, they only thing that has changed is time. Time loosens cable connections and allows them to slip which reduces throw.
Best check is to remove the cable and manually shift gears.
chucklesR is offline
post #185 of 455 Old 05-15-2013
One of None
deniseO30's Avatar
Chuck, yes had the cable off. going to try running the engine today The throw is pretty long on the trans lever. Hydraulic valve? Looks like a fork to me when I looked at the internal diagram. But I'm not one to argue It's a HBW 50 Chuck.
My last project!
post #186 of 455 Old 05-15-2013
Old enough to know better
Originally Posted by deniseO30 View Post
fluid is good. it spins. goes in Rev. If I remember right it was always free spinning when in fwd and engine was off. rebuild parts are just under $300, I've help if I have to take it out. just won't be sailing this season!
Oh I hope you aren't out all season. Not a fun job, but by all accounts it does not look to be that hard. You seem very handy, but you might be able to trade some refrigeration work for some transmission work! (I typed out tranny work, but it did not look right!:-) )
jimgo likes this.
miatapaul is offline
post #187 of 455 Old 05-15-2013 Thread Starter
Asleep at the wheel
jimgo's Avatar
Denise, let us know how it goes!
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #188 of 455 Old 05-15-2013
chucklesR's Avatar
Got that one all wrong didn't I? Missed the 'cable off' and the HBW50. My Hurth was as I described, had it replaced under warranty because the internal valve stuck.
post #189 of 455 Old 05-15-2013
JimMcGee's Avatar
Denise, best of luck. I think the stars are misaligned.
I've been doing the cutlass bearing from hell the past couple of weekends (finally done) and I still have to drop my mast and do the hull before I go in.
My buddy found major dampness in the deck around his mast. He cut out the deck and core and dried it out but has been desperate to find a fiberglass guy after Sandy. Finally got a guy started on it this week, but he's normally in in March.
A third friend just got his boat in the water and then his job sent him to Canada for the rest of the summer
I think it all started with Jimgo's boat. Everybody grab the torches and pitchforks and we'll head for his house to break the spell !!!
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
post #190 of 455 Old 05-15-2013 Thread Starter
Asleep at the wheel
jimgo's Avatar
Jim,
As long as you're assembling a work crew, would you head to Rock Hall? I bet we could get the boat repaired in no time, thereby vanquishing all of the demons that have beset our boats!
JimMcGee and utchuckd like this.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
Need an engine part that apparently doesnt exist anymore Soundtrackzz Gear & Maintenance 15 07-16-2012 01:36 PM
Summer in Southwest Florida meant for boating enthusiasts - The News-Press NewsReader News Feeds 0 06-14-2012 02:20 AM
