Apparently I'm not meant to have a boat... - Page 24 - SailNet Community
 228Likes
post #231 of 455 Old 06-14-2013
One of None
deniseO30's Avatar
Re: Apparently I'm not meant to have a boat...
Ah Ha! They need to justify the work by looking for more to do then just the DP! But yeah in for a penny in for a pound Jim. It's good news!
My last project!
deniseO30 is offline
post #232 of 455 Old 06-14-2013 Thread Starter
Asleep at the wheel
jimgo's Avatar
I think they will recommend replacing at least the rear seal, and I agree. Hoses are iffy for me, so I want to see what they see. Know they need to be done eventually, and in many ways it makes sense to do it now. Gotta add up the costs. At some point, we approach the cost of a new engine and transmission.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #233 of 455 Old 06-14-2013
bljones's Avatar
hoses you can, and should, do yourself. If your salary is less than what the yard's hourly rate is, consider doing as much yourself as possible.
It's 5 o'clock somewhere:
bljones is offline
post #234 of 455 Old 06-14-2013 Thread Starter
Asleep at the wheel
jimgo's Avatar
I'm typically inclined to DIY things. But the hoses will probably wind up being a small part of the total cost. I haven't asked yet, but I suspect they won't let me DIY in their shop.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #235 of 455 Old 06-15-2013
Is the oil soaked damping plate the cause of the major vibrations that started this tear down, and what lead you to believe the heat exchanger needed work or replacement? Didn't the transmssion work during the ferrying of the boat? I guess I'm asking for an update, on what you think your repair to be, will be.
sony2000 is offline
post #236 of 455 Old 06-15-2013 Thread Starter
Asleep at the wheel
jimgo's Avatar
It wasn't excess vibrations, it was a lack of forward progress.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #237 of 455 Old 06-15-2013
One of None
deniseO30's Avatar
Well Jim, it's certainly a good time to clean, degrease and paint the engine compartment.
My last project!
post #238 of 455 Old 06-15-2013
Tartan 27' owner
CalebD's Avatar
The good news is that there has been some progress, or movement in the right direction: fixing your engine.
Sometimes work in boat yards can take a notoriously long time which can be quite frustrating. I hope your work continues apace.
Everybody has one:
CalebD is online now
post #239 of 455 Old 06-15-2013 Thread Starter
Asleep at the wheel
jimgo's Avatar
Denise, I headed there Monday with that on the to-do list.
Caleb, despite my whining here, that's the perspective I have been keeping.
deniseO30 likes this.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #240 of 455 Old 06-17-2013 Thread Starter
Asleep at the wheel
jimgo's Avatar
I went to HH today. Mark showed me the transmission and the engine. The damping plate is certainly toast. The inside of the bell housing is all scraped up, too. The heat exchanger's zinc probably had never been replaced, so the copper is starting to wear through. There are a few hoses that do need to be replaced. There is oil in the back chamber. So, the question was, how to proceed? I really don't want to invest in rebuilding the HBW5 transmission; I've read many places that the rebuilt transmissions tend to die within a few years, and the cost of rebuilding approaches the cost of a newer transmission. So, Mark is researching replacement transmissions. If we can find one that should work, we'll go that route.
What that won't tell us, unfortunately, is whether the oil that we see inside the engine is from the transmission or from the engine itself. The oil to be engine oil, but apparently on some transmissions you could get away with using some engine-style oils. To play it safe, I've asked for an estimate to replace the rear seal. Given where we are in the process, that seems like a smart investment. I'll also be receiving an estimate for the heat exchanger.
While I was there, I cleaned out the engine compartment. It looks MUCH better than it did. It could still use some additional cleaning, but this is about as much as I'm willing to do:
I also dried out the bilge and got almost all of the oil out of it. So, now we're starting from a better place once the engine work is finished.
I also had a chance to install the bimini I made. Its a little tight, but not so much so that I couldn't get it on.
You can also see the lifeline pads and ladder pads that I made (kids complained about the ladder on the previous boat hurting their feet).
Next I need to install the "sunroof" into the bimini (helps to actually SEE the mast and sails!) and to make a "sock" to fit over the hole for the backstay, then I think I can officially sign off on the bimini and start on the dodger. I tried patterning that myself last trip, but I think I need a second set of hands for that one.
Thanks to BoatUS losing my order, I wasn't able to install the name today.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
The Following User Says Thank You to jimgo For This Useful Post:
deniseO30 (06-17-2013)
Need an engine part that apparently doesnt exist anymore Soundtrackzz Gear & Maintenance 15 07-16-2012 12:36 PM
Summer in Southwest Florida meant for boating enthusiasts - The News-Press NewsReader News Feeds 0 06-14-2012 01:20 AM
