Apparently I'm not meant to have a boat... - Page 44 - SailNet Community
 228Likes
post #431 of 455 Old 08-05-2013
chef2sail's Avatar
Re: Apparently I'm not meant to have a boat...
Originally Posted by jimgo View Post
BTW, wasn't discounting the advice. Just thinking that it wouldn't be hard to put it back in in the future, and at this point we're probably going to be staying in the Bay at least into 2015. I expect/hope to be pumping out regularly, too.
But your point about "emergency" situations is well made.
Can you leave the Y in then, to make it easier in case you decide a different place to put the pump at a layer date, then youll only have to add hose and pimp. Where's the holding tank located? How large is it?
I understand the room thing. I've seen that when everything is in the head especially. That's always an important factor and every boat is different. We lived without a mascerator for 4 years. Once we started traveling, offshore it was a no brainier, and all off our stuff, including the holding tank is under the v berth where there is a ton of room.
The y is located after the holding tank.one branch to the deck pump out, the other to the mascerator and thru hull.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #432 of 455 Old 08-05-2013 Thread Starter
Asleep at the wheel
jimgo's Avatar
We have a u-shaped dinette on the port side, and the holding tank is under the forward portion of the "U", immediately next to the head. The thru-hull for the raw water is on the port side, and eats up space too.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #433 of 455 Old 08-05-2013 Thread Starter
Asleep at the wheel
jimgo's Avatar
In thinking about it more, I don't think I can do the KISS holding tank arrangement because my tank is below, or nearly below, the waterline.
I'd love to order the hose so I could have it for this weekend, but I have no idea how much I need, and at $7.50/foot, I don't want to over-order by too much!
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #434 of 455 Old 08-05-2013
Tartan 27' owner
CalebD's Avatar
Originally Posted by Minnewaska View Post
Is the holding tank in the head? If not, the smell would not be from failing to pump it. If it is, they're usually not a permeable material, so its probably the hoses that stink, or possibly leaking connections. Permeated hoses and bad connections never get better and your wife may always turn her nose up....
I would replace them. Lousy job, not terribly expensive, but is DIY. Most people do not take proper care of onboard waste systems and cause odor. They should not smell. If you start over, you can insure they never do. Get Peggy Hall's book Get Rid of Boat Odors. It's the bible. Your wife will thank you and you won't be on the receiving end of criticism when you just want to go cruising.
Get Rid of Boat Odors: A Boat Owners Guide to Marine Sanitation Systems and Other Sources of Aggravation and Odor: Peggie Hall: 9781892399151: Amazon.com: Books
Then get Raritan K.O., which I think she invented and sold them the rights.
+2 or 3 on the Peggy Hall book. She was the ultimate Head Mistress after all.
I did not know that she invented the formula for KO? I swear by K.O.
Somewhere in her book(let) she suggests that wiping down inside your lockers & hoses with K.O. will help "kill odors", which is what the "KO" stands for. Perhaps you could use the gallon size container for wiping down your inside cabin surfaces as well as head tank treatment?
MedSailor likes this.
Everybody has one:
CalebD is offline
post #435 of 455 Old 08-05-2013
chucklesR's Avatar
I"m tied up the 18th, which is a bummer.
chucklesR is offline
post #436 of 455 Old 08-05-2013
One of None
deniseO30's Avatar
"sniff, sniff" wass dat smell? Looks around... "oh the winds a blowing up from the chessy"
(goes back to her rock and hides)
My last project!
deniseO30 is offline
post #437 of 455 Old 08-05-2013
Chastened
Ajax_MD's Avatar
The Chessie only smells that way, because PA treats it like their own, personal toilet bowl via the Conowingo dam. It must be nice to live "upstream".
1981 Tartan 33 #168
Ajax_MD is offline
post #438 of 455 Old 08-05-2013
One of None
deniseO30's Avatar
here it all flushes down to Delaware Bay. the Susquehanna is the bad guy not me!
My last project!
post #439 of 455 Old 08-05-2013 Thread Starter
Asleep at the wheel
jimgo's Avatar
Bubble, I think Denise was referring to my boat, not the entire Chesse!
miatapaul likes this.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #440 of 455 Old 08-21-2013 Thread Starter
Asleep at the wheel
jimgo's Avatar
For those still following this thread, Dragon Wing is in her new slip. We left Rock Hall on Sunday, spent the night in shallow water behind Reedy Island in the Delaware, and then headed to Cape May on Monday. We made the trip from Utsch's to Forked River today.
Thank you all VERY much for all the encouragement, good wishes, and helpful advice. The trip went off without a hitch, and I give y'all a lot of the credit.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
Need an engine part that apparently doesnt exist anymore Soundtrackzz Gear & Maintenance 15 07-16-2012 01:36 PM
Summer in Southwest Florida meant for boating enthusiasts - The News-Press NewsReader News Feeds 0 06-14-2012 02:20 AM
