TV/monitor ?? - SailNet Community
post #1 of 4 Old 04-06-2013 Thread Starter
deltaten's Avatar
Send a message via Yahoo to deltaten
TV/monitor ??
I've gotten the all the other bits'n'pieces for my smartphone lash up and now need the display. I would like to use it for web work, DVD viewing and the odd Netflix; once the free Wi-Fi is set up. Oughta be 1080p with HDMI input required; but have seen some with 720 that had same.
Problem I'm having is size! I wish to mount/store it inside/behind the fold-up table; and that will only be close to 15.5"-16" available width. Seems most of the "name" brands are not making anything less than 19" wide-screens anymore. I *did* find RCA; but we all know what a crap shoot that can be.
Anyone ever hear of or use; Naxa? Coby? Curtis? Proscan? Venturer? Pyle (in-wall)? Scepter? or can review any of the other "off" brands that work well? I did find one Haier at 15.6 inches; but can't find an actual width on amazon!
TIA,
Paul
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #2 of 4 Old 04-06-2013
no longer reading SailNet
Alex W's Avatar
Re: TV/monitor ??
Two ideas:
1) Get a computer monitor. You can probably find a used 15" to 17" one for nearly free.
2) Get a computer monitor that rotates into portrait mode. You can then rotate it when folding up the table. There are a lot of 20" ones that will be less than 15" tall (or 15" wide when rotated). Most wall mounts allow for this rotation, so you might not even need to find such a monitor.
I personally just use a laptop, it's nearly as big and a lot easier to put away.
Alex W is offline
post #3 of 4 Old 04-06-2013
Re: TV/monitor ??
In the days when TV's were expensive, we tried to do our homework and find one that had a decent service reputation. Nowadays, they so cheap....just buy one that fits your needs and don't worry about it. chances are it will last longer than you need and if not, you're not out much money if you have to replace it.
Catalina 34
chuck53 is offline
post #4 of 4 Old 04-06-2013
Puget Sound Pounder
kellysails's Avatar
Re: TV/monitor ??
I would get a monitor with a tuner (ie... a TV). The price difference is so little these days between a monitor with/without tuner. And if you could stuff a quality UHF antenna in a locker somewhere you would be surprised on the number of channels you could pick up, HD even. You don't need a super expensive antenna mount. The beauty of digital is that you either a great pic or no pic, no fuzzy reception these days. It is surprising what you can pick up.
kellysails is offline
Monitor vane on 31? adamowens Pacific Seacraft 13 12-22-2009 07:46 AM
Battery Monitor trantor12020 Gear & Maintenance 4 03-06-2009 11:35 AM
marine monitor dbpaul Catalina 0 01-17-2008 12:16 PM
Tv/dvd On Boat What Is The Best Monitor 82Venture22 Gear & Maintenance 21 01-17-2008 05:24 AM
Monitor Windvane hooliganx6 Gear & Maintenance 4 10-20-2001 06:07 AM
