Using sailboat without sails. - SailNet Community
 3Likes
post #1 of 19 Old 04-09-2013 Thread Starter
This might be a blantantly newbie question but does anyone ever use a smallish sailboat with just an outboard? In other words, taking it out and leaving the sails behind? I have a 17' which I am a ways away from gaining enough experience to take it out in the back bay area. However, I am interested in still using it for crabbing and clamming. Since I plan to eventually get a small outboard for it anyway, I figured I could get one now and make use of the boat until I am competent enough to sail her.
Ei Leen is offline
post #2 of 19 Old 04-09-2013
Re: Using sailboat without sails.
Why so shy? Certainly you can do as you suggest, but take the sails with you and play around on the right day(s). Waiting isn't going to prepare you, only practice will .. unless you're getting that experience on OPBs (Other Peoples Boats)
Faster is offline
post #3 of 19 Old 04-09-2013
sailvayu's Avatar
Most sailboaters use their engine more than they care to admit. It is all about getting out on the water and having a good time. Just make sure you do not over power the boat and that the transom can handle what ever motor you put on. A motor might help you with learning to sail, give you a bit more confidence knowing you can get back. We were all new at one time so like they say the only dumb question is the one not asked.
CalebD and 34crealock like this.
Capt. Wayne Canning, AMS
sailvayu is offline
post #4 of 19 Old 04-09-2013
Philzy3985's Avatar
What kind of 17' sailboat is it?
If there's a hole in the center (for a daggerboard/the keel) then just keep in mind that the bottom might always be taking on a little water, especially if motoring at a good speed they can basically flood themselves. When I towed my old small sailboat in the water I stuffed the hole with towels to plug it up, it worked alright...If the boat has a fixed-keel then it's going to move a little more like a sailboat in the water, and be difficult to counter-maneuver in current with your outboard, but you can make it work.
Nothing wrong with your idea, though. get the most out of it while you own it, and remember it can be sailed.
1985 Catalina 30 Std Rig "A Cenoura"
itsACenoura.tumblr.com
Philzy3985 is offline
post #5 of 19 Old 04-09-2013
krisscross's Avatar
At one time I was using my Holder 14 (without the mast, sails, dagger board and rudder) with a 5HP outboard. Since the motor mount on this boat is off-center, it was prudent for me to sit on the opposite side of the mount to balance the boat better. The boat was stable and quite fast. I don't recall taking water through the dagger board box - mine is quite high, or I was not going fast enough.
krisscross is offline
post #6 of 19 Old 04-09-2013
Barquito
Barquito's Avatar
Some dinghy sized sailboats double as row boats or motor boats. Good for fishing, etc.
Ideal learning conditions are not too slow, not too fast (maybe 10 kt wind). But, despite the forcast, you never know when that will actually happen. So, bring sailing gear along even if you don't plan on sailing.
mountaintrout likes this.
Bristol 27
Cirque
Barquito is offline
post #7 of 19 Old 04-09-2013
denverd0n's Avatar
Sure. I have a 15' sailing dinghy that I sail 90% of the time, but now and then I just want to get somewhere, and then I'll leave the mast and sails at home and just use the motor. Why not?
denverd0n is offline
post #8 of 19 Old 04-09-2013
bljones's Avatar
one does not gain experience by leaving the sails behind.
Get out there and give it a try. Pick your weather, and I 100% absofreakinlutely guarantee you will surprise yourself.
Use your outboard when an outboard is appropriate.
yeah, I sometimes simply fire up the iron genny when the wind is too light to move my pig of a boat, and we just want to head out of port to "bake and bob'.
It's 5 o'clock somewhere:
bljones is offline
post #9 of 19 Old 04-09-2013
Master Mariner
capta's Avatar
Humans have been sailing some 5000 years; it ain't rocket science! There is nothing wrong with what you want to do, but with summer and light winds just around the corner, it's not a bad time to begin sailing. As long as you have a reliable outboard, you can always lower the sails if you feel you are out of your depth. I suggest "Royce's Sailing Illustrated" as a fun introduction to sailing.
The biggest sin in owning a boat is never using it.
Have fun.
facebook.com/svskippingstone
Our Videos;
capta is offline
post #10 of 19 Old 04-09-2013
Remember you're a womble
PaulinVictoria's Avatar
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
Apollo 16 Sailboat Sails William Jasulaitis Introduce Yourself 5 03-22-2013 08:58 AM
Racing Sails Vs. Cruising Sails??? NewportNewbie General Discussion (sailing related) 2 10-27-2011 03:25 PM
North Sails vs North Sails Direct DrB Gear & Maintenance 0 06-25-2009 10:00 PM
Teralani Sailing Adventures - Snorkel Sails, Sunset Sails and Whale Watched from Kaanapali Beach, Maui (About.com) NewsReader News Feeds 0 10-06-2006 12:15 PM
new sails mikehoyt Racing 9 09-10-2002 12:52 PM
