Pop rivets: AL vs SS - SailNet Community
post #1 of 11 Old 04-11-2013 Thread Starter
Any opinions are the use of aluminum vs. stainless steel pop rivets? I have a few items that I would like to fasten to my mast and boom. I've tapped out holes in the past and used SS screws but my heavy hand has occasionally stripped the hole. I've used AL pop rivets and find that they are more convenient. I came across a catalog entry for stainless steel rivets and was wondering if their greater strength is outweighed by the possibility of corrosion between them and the mast material.
nestorph is offline
post #2 of 11 Old 04-11-2013
Boasun's Avatar
Re: Pop rivets: AL vs SS
if you coat the SS rivets with sealent you shouldn't have any problems... Any way that is what the books tell...
But then who trusts what they are reading??
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Boasun is offline
post #3 of 11 Old 04-11-2013
Wish I never found SN!
SimonV's Avatar
Pay a bit more and use Monel Alloy rivets. Thay are formed from a special copper – Nickel Alloy and are particularly suited for Stainless steel and aluminum in corrosive environments.
Simon
I miss my boat
Brisbane
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #4 of 11 Old 04-11-2013
Owned by Velcro
Ferretchaser's Avatar
The real problem with aluminum rivets is, that the shear pin in the middle of them is made of mild steel, so they tend to rot from the inside out. It pays to take a magnet with you when buying rivets as even the cheaper stainless steel ones have a mild steel inner, defeating the object of the whole operation.
ATB
Michael
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
Light travels faster than sound. That is why some people appear bright until you hear them speak!.
Ferretchaser is offline
post #5 of 11 Old 04-11-2013
There is no shear pin in cheap pop rivets, go for structural rivets like Cherry Q series (available in Monel)
rd1900 is offline
post #6 of 11 Old 04-11-2013
Cruiser2B's Avatar
I replaced the aluminum rivets in my boom with quality stainless units. I coated each very liberally with tefgel..So far so good( only been a year though). My reason for putting stainless was a guy on the dock sheered all but one of the aluminum rivets from his gooseneck( Alberg 30 same boat as mine) So I inspected mine and while they were all in good shape they were 40+ yrs old. So I drilled them out and replaced with ss rivets using plenty of telgel as recommend here on sailnet.
Good luck
My two lovely ladies!!
USCG 100T Near Coast Master with 100T Inland Sail Endorsement
Cruiser2B is offline
post #7 of 11 Old 04-11-2013
Monel would be a good idea, but I would be concerned with halyards chafing on the protruding pieces for the ones on the mast.
SVTatia is offline
post #8 of 11 Old 04-11-2013
Go to McMasterCarr, and order the 1/4" s/s, high strength rivets in 18-8 stainless. 2450 lbs sheer EACH. You'll need one of these to install them :
http://www.amazon.com/AES-Industries-286-Rivet-Gun/dp/B002DLYQQI
Install with plenty of Lanocote or Tefgel and you'll have a solution that will outlast the boat, you, and probably modern industrial society.
MarkSF is offline
post #9 of 11 Old 04-14-2013
Yup I have seen aluminum pop rivets fail in a structural situation, on more than one boat. The crew I race with wont use them for anything more loaded than a light fixture...
peterchech is offline
post #10 of 11 Old 04-14-2013
pdqaltair's Avatar
In addition to comments by others, it's a matter of engineering.
3/16-inch SS rivets are very common on many beach cats and easily outlast the boat, if properly applied. They do well when holding something thin (plate or flange) that will be purely in shear (mast hounds) and sometimes small blocks (1/4-inch line). They never seize (rather they are always drilled-out and it is easy). But they are quite susceptible to working loose if the force has a lifting component and can shear if they are not:
* installed tight
* holes drilled correctly
* load not evenly distributed
* enough; too few
* SS or monel. aluminum is simply too weak.
A matter of horses for courses. Tapped machine screws are better if the section is thick enough, nuts are better when possible, but rivets have a place in thin sections (dingies) where threads won't hold.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
Monel rivets Turk123 Gear & Maintenance 11 08-06-2013 06:16 PM
What size rivets? TSAKUS Gear & Maintenance 1 06-08-2011 03:15 PM
Rivets! polson Gear & Maintenance 10 04-19-2009 09:19 PM
pop rivets or machine screws? groundhog Gear & Maintenance 7 06-01-2007 08:03 AM
Rivets Tom Wood Gear and Maintenance Articles 0 08-20-2000 08:00 PM
