Check out my sheet to tiller steering - SailNet Community
 6Likes
  • 6 Post By lans0012
post #1 of 10 Old 04-11-2013 Thread Starter
Daysailor wannabe cruiser
lans0012's Avatar
After reading some threads on here about sheet to tiller steering I had to try it out. I finally found some blocks that could snap on to the genoa track and also to the stern pulpit and got the lowest stretch small diameter line I could find at WM.
I also cut some bungees to size of varied thickness and strength for the resistance.
So I've since found out that this simple idea actually works on my boat, a 85 Cal 27 MK 3. It sails a close reach to close hauled very well with no input on the tiller.
Today it was blowing S 15 kts gusting to mid 20's on Tampa Bay so I had to take it out and take some pics. My bungees found a hiding spot on the boat so they are not pictured. You don't really need them on my boat when the wind is steady around 15kts. She needs some weather helm to stay straight.
Anyway once you set it up there's nothing left to do so I waited for a good shot of the rail down in a gust from my vantage sitting/standing on cabin top.
Check it out.
lans0012 is offline
post #2 of 10 Old 04-12-2013
KNOT KNOWN
Capt.aaron's Avatar
Re: Check out my sheet to tiller steering
Cals will do that. I like 'em. My 65 Soverel 28 does it pretty well with a tied off tiller close hulled. great picks. I just did the first stage of installing my new Capehorn wind vane yesteday, finishing today.
" Some are boat wise and some are other wise"
Capt.aaron is offline
post #3 of 10 Old 04-12-2013
Tundra Down
downeast450's Avatar
Ians, your solution looks great and is where I am with using the wind to help me steer. Capt.arron, please post some pictures of your instal too, if possible.
Thanks,
Down
downeast450 is offline
post #4 of 10 Old 04-12-2013
denverd0n's Avatar
Very cool.
denverd0n is offline
post #5 of 10 Old 04-12-2013
HardTAC's Avatar
Nice pictures, and a great way to minimize the use of your autohelm (and battery power)!
HardTAC is offline
post #6 of 10 Old 04-12-2013
Chastened
Ajax_MD's Avatar
I need a little clarification.
I see the bungee from the stern pulpit to the tiller.
I see what looks like a small line across the cockpit, going to the lazy jib track.
What is connected to what, in this photo?
Thanks.
1981 Tartan 33 #168
Ajax_MD is offline
post #7 of 10 Old 04-12-2013 Thread Starter
lans0012's Avatar
The small line tied to the mainsheet is going across the cockpit and routed to the tiller on the windward side. It is attached to the tiller via a slip knot one of my rock climbing buddies showed me that works really well. You just slide the knot up to add more tension. In the pic the knot is about 3 inches away from the block. This is fine because you only get a couple inches pull from where I had it attached to the mainsheet.
In a gust the mainsheet loads up and pulls the little green line which s pulls the tiller to windward. This gives you enough weather helm to maintain course and not round up in gusts. After the gust the main depowers and eases the tiller to give less weather helm.
You are supposed to use bungees on the opposite side to pull the tiller to leeward in a lull so you don't fall off and jibe. The wind was strong enough yesterday where the boat still had weather helm in the lulls.
lans0012 is offline
post #8 of 10 Old 04-12-2013
Chastened
Ajax_MD's Avatar
This sounds very cool. I now see where the small line is tied to the mainsheet, but all I see on the tiller, is the bungee.
Sorry to be a pest, but this is pretty interesting. Would you mind posting a diagram and parts list for the visually impaired?
1981 Tartan 33 #168
Ajax_MD is offline
post #9 of 10 Old 04-12-2013 Thread Starter
lans0012's Avatar
I'll see if I can put something together or take some pics this weekend. There are actually no bungees on the tiller in the pics. I couldn't find them yesterday and still can't. When it is windy enough I don't really need the bungees.
The loop around the tiller is the green line that is routed from the mainsheet. It is held in place on the tiller with friction and the little metal job where the auto tiller would mount.
I'll find some better pics but there are other diagrams out online and youtube videos...just google sheet to tiller steering. My setup is very basic but works well for my boat. This doesn't work downwind...haven't started on that one yet.
lans0012 is offline
post #10 of 10 Old 04-12-2013
Swab
vega1860's Avatar
We have sailed thousands of miles with nothing more than a piece of surgical tubing running from the tiller to a windward cleat.
"What! You mean you do not have to go out and spend a few thousand $$$ for brand name self steering gear??"
vega1860 is offline
sheet to tiller on a wheel seabrookedan News Feeds 5 11-17-2012 09:24 PM
Sheet to Tiller or Windvane? Cruiser2B General Discussion (sailing related) 15 06-26-2012 01:31 PM
Tiller to sheet self steering davidpm General Discussion (sailing related) 9 09-20-2011 08:11 PM
Steering Pedestal Upgrades W/ Cockpit Mounted Main Sheet Maine Sail Gear & Maintenance 8 08-04-2007 08:19 PM
Tiller vs Outboard for steering OregonBob Learning to Sail 4 04-04-2005 09:49 AM
