Restoring those plastic sink cover cutting board things... - Page 2 - SailNet Community
 23Likes
post #11 of 71 Old 04-15-2013
Re: Restoring those plastic sink cover cutting board things...
Unless cleaned and sanitized in the proper way wooden cutting boards are more likely to harbor bacteria in the cracks and crevices than the plastic ones. In many areas the health departments do not all them in commercial kitchens. I suggest a minor expenditure and by new plastic ones.
(I expect t37chef my friend o is agree as it is a topic we both have differing views)
One thing we both would agree upon is that the board needs to be free of grooves and places which would prevent good cleaning and that good sanitation techniques are required no matter hat material. Sanding plastic will open the pores o allow fools debris to be trapped and encourage
bacteria.
USDA Food Code allows both wood and plastc
Dave
Hi Dave,
We certainly agree that whatever material is used must be easily cleanable.
I have found little scientific evidence though that wood is " more likely" to harbor pathogens than plastic.
In industry, the biggest issues I see with plastic boards are: That they are often allowed to remain in service too long after becoming scarred and stained. And, that they are often put away wet and stacked, rather than allowed to " air dry" vertically and not touching. My university's micro-lab has done extensive testing on this stacking vs. standing issue.
The FDA issues the Food Code and the USDA contributes. It's guidance to industry. I suspect that those health departments that have banned wood have done so for a variety of reasons: The " old" wood-top tables that were often poorly maintained and required cleaning and sanitizing " in place".
And, that plastic boards hold up better under repeated high temperature sanitizing in dishmachines than wood, and therefore are more likely to be sent to the machine by the user than wood. Health departments take a risk-based approach and typically don't trust that people will use the proper dillution rates, contact times and air drying for chemical sanitization. In either case, the industry has gone to plastic. Plastic is also less expensive.
For Home use, there was this study done by some folks at UCDavis:
UC-Davis Food Safety Laboratory: Cutting Board Research
Like you said, Either material works, as long as it's easily cleanable, and handled properly.
chef2sail likes this.
tempest is offline
post #12 of 71 Old 04-15-2013
chef2sail's Avatar
Yes I agree,
Since the topic is for boat use I still suggest that the plastic ones re the ones most easily sanitized by boars and more likely to be replaced when necessary than the wooden ones.
I would be very few people with wooden ones bleach them after use or even wash, rinse and sanitize them properly
On Haleakula our decorative vanished and protected butcher-block cutting board sits on our stove top. We have a small thin light weight inexpensive ( Less than %10) plastic board to put on top when knife magic is required.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #13 of 71 Old 04-15-2013
Señor Member
PorFin's Avatar
...that the plastic ones re the ones most easily sanitized by boars and more likely to be replaced when necessary than the wooden ones...
Now, I've heard of crew "living like pigs" and "acting like pigs," but I've never seen actual pigs as crew doing galley chores...
Sorry, Dave, I couldn't resist
chef2sail, CalebD, bljones and 1 others like this.
________
'85 BYB Vagabond 39
PorFin is offline
post #14 of 71 Old 04-15-2013
Ask for offcuts at a plastics place.. they will often have partial sheets or off cuts at a bargain price.
Faster is offline
post #15 of 71 Old 04-15-2013
Señor Member
PorFin's Avatar
+1 on the suggestion about cut-outs. In addition to the plastics places, check with kitchen countertop installers.
________
'85 BYB Vagabond 39
PorFin is offline
post #16 of 71 Old 04-15-2013
T37Chef's Avatar
Yes I agree,
This is exactly the point I disagree with you about Dave. I agree that using wood in a commercial kitchen more often than not does not make sense, economically or safety...on a boat however where most do NOT have a high temp dishwasher, I don't like plastic. I would never bleach my wooden cutting boards anyway, only soapy water and rinse followed by a white vinegar rinse. Wood has absorbing qualities plastic does not, thats the most basic difference...if you remove or reduce the moisture from the boards a pathogen it will die just like a dried food, cured foods, etc.
SVAuspicious likes this.
Shawn
T37Chef is offline
post #17 of 71 Old 04-15-2013
TQA
Bombay Explorer 44
TQA's Avatar
OK got my new board which is oversize. What kind of jigsaw blade should I use?
TQA is offline
post #18 of 71 Old 04-15-2013
Cut a plywood template and use a router with a tall enough laminate trimming bit.
Faster is offline
post #19 of 71 Old 04-15-2013
Has anyone tried to grow plants under a pine or spruce tree? It won't happen. That's why wood is superior as cutting board. The sap kills the bacteria.
sony2000 is offline
post #20 of 71 Old 04-15-2013
Selkie60's Avatar
I recently received a Corian cutting board that came with the following cleaning instructions, which might be applicable to other types of plastic cutting boards...
"Stubborn stains rub off with an abrasive household cleanser and a Scotch-Brite pad. Even tougher stains disappear using fine grade (180-220 grit) sandpaper. Buffing afterwards with a Scotch-Brite pad will return the surface to its original matte finish."
Capt Chuck
S/V Selkie
Selkie60 is offline
cutting board as backing plate material? johnnyandjebus Gear & Maintenance 17 12-08-2011 12:47 PM
Galley cutting board brokesailor Gear & Maintenance 17 07-26-2011 12:05 PM
Looking to replace the bilge board/cover n0w0rries Gear & Maintenance 1 08-14-2009 04:03 PM
Cutting floor board? saltypat Gear & Maintenance 16 01-06-2008 10:37 PM
Plastic paint for tired looking plastic parts Goodnewsboy Gear & Maintenance 3 01-01-2007 06:15 AM
