How often to change outboard motor oil? - Page 2 - SailNet Community
 1Likes
post #11 of 11 Old 04-15-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
Re: How often to change outboard motor oil?
not getting the engine up to temp is the worst thing you can do to an engine. The oil never warms up to properly coat all the internal friction surfaces, it never cooks off the water and fuel contamination, and the water vapor in the exhaust never gets burned off/out so it causes corrosion in the entire exhaust system. If you don't need to run it much to get in and out of the marina, consider once a week or so just running it (in gear under a load) for 20 minutes or so just to get it up to a really hot temp.
The wasted fuel is cheaper than a rebuild
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
best outboard motor? Kiltmadoc General Discussion (sailing related) 11 05-28-2011 03:07 PM
Outboard motor won't pee dbrock010 Gear & Maintenance 31 03-04-2011 05:05 PM
Outboard - Change Water pump or just impeller Finallybuyingaboat Gear & Maintenance 5 04-13-2008 08:34 PM
outboard in motor well... tenuki Gear & Maintenance 14 05-22-2007 11:19 PM
