Keel cutter, this is sick! - SailNet Community
 4Likes
post #1 of 21 Old 04-16-2013 Thread Starter
One of None
deniseO30's Avatar
Years ago we used a circular saw with special blade to cut aluminum diamond plate for a walk in box. Never thought of this!
My last project!
deniseO30 is offline
post #2 of 21 Old 04-16-2013
美国华人, 帆船 教授及输送
Re: Keel cutter, this is sick!
I think that a circular saw will do a better job than a chain saw. Using a 2x4 as a guide, it will come out even prettier.
Fine Print:
I am old school. Integrity is to do the right thing even when no one is watching.
rockDAWG is offline
post #3 of 21 Old 04-16-2013
Okay, I watched. They probably destroyed the chain on the chainsaw, made a lot of lead flakes (47 pounds!) and got the keel cut into two pieces. But why? I'm not being sarcastic, I cannot think of any reason to cut the keel up like that. Will the recycle center not accept as one big piece?
sd1953 is offline
post #4 of 21 Old 04-16-2013 Thread Starter
One of None
deniseO30's Avatar
Maybe he didn't have the means to lift it?
My last project!
post #5 of 21 Old 04-16-2013
travlin-easy's Avatar
Hey Denise. Are you coming down to the Sailnet Rendezvous in June? I would love to see you again.
Gary
travlin-easy is offline
post #6 of 21 Old 04-17-2013
I don't discuss my member
Fstbttms's Avatar
According to the video, they want to smelt the lead and cast bullets.
Fstbttms is offline
post #7 of 21 Old 04-17-2013
chucklesR's Avatar
47 pounds of flakes would make a lot of bullets.
Your basic cut off saw is just as fast, more accurate and less wasteful.
chucklesR is offline
post #8 of 21 Old 04-17-2013
Tundra Down
downeast450's Avatar
I have cut up a lead keel. It is soft stuff. Obviously a chain saw works. I discovered the importance of WD-40 and taking it slow when using a skill saw. It will heat up and melt, binding the blade if you are not careful. WD-40 and a carbide tipped skill saw blade go through it like butter. Handling lead is an unappreciated hazard. Lead dust, oxide, fumes etc. are potentially very harmful and long lived. The size of the chips produced using a chain saw might be safer than the smaller particles produced with a skill saw or even a hand saw. Preparing to catch everything is an important bit of preparation for the safety of those doing the work and any innocents who come across it later. Gloves and a respirator.
Down
jameswilson29, rugosa and Jgbrown like this.
downeast450 is offline
post #9 of 21 Old 04-17-2013
Most 24hr clinics do lead poison tests relatively cheap. If I were working with it, I'd get tested regularly.
I used to shoot revolvers with some folks on a frequent basis, a number of which would shoot lead. I did for a brief period (it's cheap), but stopped after I found out several of them had encountered health problems due to long term usage and handling of lead rounds. In a few cases, just a small bit of exposure was all that was necessary for lead poisoning to take effect.
Shinook is offline
post #10 of 21 Old 04-17-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
lead poisoning is incredibly insidious and you do not need a lot of it to get poisoned.. and getting over it can takes decades
downeast450 likes this.
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
Pearson 367 Cutter vs Hunter Cherubini 37 Cutter coma01 Boat Review and Purchase Forum 7 02-16-2012 11:54 PM
Sea Sick Jay2 Learning to Sail 42 06-24-2009 07:50 PM
turning a sloop rigged cutter into a cutter (different) aurielthirtyfour General Discussion (sailing related) 5 07-11-2007 10:33 AM
turning a sloop rigged cutter into a cutter (different) aurielthirtyfour General Discussion (sailing related) 3 07-10-2007 08:37 PM
