Basic marine deep cycle battery questions - Page 2 - SailNet Community
 4Likes
post #11 of 16 Old 04-19-2013
Large Member
Re: Basic marine deep cycle battery questions
One problem about the outboard... that rating is the max. output at full throttle.
KBuckley likes this.
mdbee is offline
post #12 of 16 Old 04-19-2013
no longer reading SailNet
Alex W's Avatar
If you are concerned about battery life or don't already have an onboard battery system you could also consider a portable anchor light and VHF radio. The anchor light can be raised on a halyard (using a messenger line to bring it back down). Handheld VHF radios will last about 15 hours on a charge. When kayaking I've found that to be adequate to last me more than a week if I only tune in during major crossings or when trying to hail someone.
A basic solar charging system is under $200 and really worth it. If you don't have the alternator for your outboard then I'd get the solar charger first. A 20-30w panel and a Genasun MPPT charger should keep your battery topped off and recharge for light battery use.
If you think that you'll want to add a tillerpilot down the road then a good house battery system will become a requirement.
Alex W is offline
post #13 of 16 Old 04-19-2013
chucklesR's Avatar
Others have already addressed the 'what's watt' issue of amp hours and usage.
There is no such thing as a standard battery - you need to look up yours and see what it it rated at, then because you have no idea what the current state of it is (age, condition) go with a safety factor that only you can determine (i.e. 80%).
Voltage can be used as a simple indicator of state of charge, but it's not totally accurate. There are many threads here discussing that (search 'voltage state of charge').
For extra 'hang time' on the hook there are lots of options, solar, wind, low amp anchor lights etc..the idea is either put the amp's back, or reduce the use.
Be realistic on what a anchor light draws - the old ones are 1.5 or more amps per hour - for 30 bucks you can get a perfectly legal LED base hook on the back stay type and it will draw .1 amps.
Solar - calculate your gain to a charged battery based on a simple rule of thumb - you'll get 25% of the watt rating in amp hours (e.g. 100w panel, 25 amp hours) per day.
A 20-30w panel is a fine trickle charge over a week on a mooring, it will not significantly extend anchor hang time.
If budget is a concern you can get a 900w gas generator at Harbor Freight for under a 100 bucks. They are loud, smelly and use gas - but - they are cheap, almost disposable and great for that time when you do in fact kill the battery.
chucklesR is offline
post #14 of 16 Old 04-19-2013
The VHF will have two power ratings. One for transmit (one one for high power, one for low power) and one for receive (with squelch off).
The rule of thumb is that you will be transmitting perhaps 10% of the time compared to the receive, so if the radio draw 3A on transmit and 0.1A on receive, you would average that as about 0.39A for average power used.
You CAN also buy an "alarm and exit lighting" battery, or get a car "jump box" that has a battery like that in it, and keep that as an emergency-only battery for the radio, etc. Most of the jump boxes are big boxes with small batteries inside, so buying just the battery from a discounter can be way more effective if you don't need the box, cabling, charging cord, etc that the jumper box puts together.
hellosailor is offline
post #15 of 16 Old 04-19-2013
deltaten's Avatar
Send a message via Yahoo to deltaten
I just picked up one of those small batteries from my Interstate dealer for a 10million CP spot lite. OTD price was a couple cents more than $26 !. Generally used in computer back-ups, fire/security alarm and emergency lighting. 12v AGM rated 7 AH..as is written on the side of the batt.
Whether it would start my Beta20 or not..I dunno; but it would run a buncha LED lites for quite some time.
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #16 of 16 Old 04-19-2013
Dunno about the beta but I've used a 17AH battery to start an Volvo MD6 or MD7, I forget. All parties were happy with the result.
Are All Deep Cycle Batteries Alike? chuck711 Gear & Maintenance 24 09-15-2015 03:48 PM
Deep Cycle Battery Brand Selection GlacialEratic Electrical Systems 8 03-23-2010 03:45 PM
CD Player and a Deep Cycle Battery mountforever Gear & Maintenance 5 09-14-2009 12:07 AM
Starting battery and deep cycle - charging ChesapeakeCal29 Electrical Systems 16 08-18-2009 10:17 PM
Using a deep cycle battery for starting? MedSailor Electrical Systems 9 07-11-2009 05:54 PM
