Like Tree1Likes
  #1
Old 04-18-2013
northoceanbeach's Avatar
first sailed january 2008
northoceanbeach is on a distinguished road
What to do if a shroud or stay breaks
I was reading a book on cruising and it got me thinking. I need to know what to do if a shroud breaks. I should be able to do it without even thinking. The book says:
'the mast of a cruising boat should be of sufficient diameter and wall thickness, and the rigging of adequate strength, that even if one part of the rigging should give way, the mast will not break or sustain a permanent bend, if corrective action is taken immediately.'
So I guess I need to know what corrective action to take. Is it dependent on which part breaks? Or do you pretty much round up into the wind to depower the sails. That's the first action that comes to the top of my head, but there might be better ideas, and I would like to hear them.
  #2
Old 04-18-2013
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
Re: What to do if a shroud or stay breaks
It all depends on which wire fails. If the forestay breaks on a boat with no inner stay you may not have time to do anything before the mast comes down. If a lower shroud (or even an upper shroud) breaks you might have time to tack or jibe to put that shroud on the lee side. In heavy winds any wire breaking could bring down the mast faster than you can do anything about it. In light winds you would probably have a better chance; but that isn't when things are likely to break, now is it?
Face it, modern Bermuda-rigged boats just don't have a lot of redundancy built into them.
LET'S GET SERIOUS ABOUT GUN CONTROL, NOW!
  #3
Old 04-18-2013
BayWindRider's Avatar
I'm Jon, I'm a sailaholic
BayWindRider is on a distinguished road
I've seen a couple of cruisers carry rigging cutters just in case the mast comes down. You can probably get away with a hack saw as well. I'm sure during a confused or rough sea state you wouldn't want to have an unsecured mast bouncing around on or near the boat. That would be catastrophic in my mind. In that case the saw or the cutter would be used to send the mast to the bottom. I'll be damned if I'd be fooling with some clevis pin to detach a stay from the chainplate. Just cut the sucker...
S/V Dulcinea, Catalina 27
  #4
Old 04-18-2013
PCP PCP is offline
Try to replace its function with the help of halyards, if you have enough fuel return port under engine, if not sail slowly with deeply reefed sails.
I have saw many getting away with these measures, specially the last one in solo races. I even saw a guy continue to race (more slowly) under these circumstances and finishing the Transat.
Varietas delectat
  #5
Old 04-18-2013
denverd0n's Avatar
denverd0n is on a distinguished road
The idea is that you want to change your point of sail to relieve the pressure from the broken rigging. So, if you're on a starboard tack and the starboard shroud breaks, as quickly as possible you go to a port tack. If you're running downwind and the backstay lets go then you head up into the wind as quickly as possible. On any particular point of sail there will be some part of the rigging that is taking the majority of the strain, and some part that is more or less loose. Shift the point of sail so that the broken stay is one of the loose ones.
Of course, like SlowButSteady said, there's a good chance the mast is going to come down anyway.
  #6
Old 04-18-2013
outbound is on a distinguished road
As said above change point of sail to unload broken stay. If you have running backstays reef so sail below point of attachment and deploy. If you have spare halyards use to replace function of broken stay. If halyard external attach one end to chain plate. Attach block as close to possible to chain plate. Then run other end through block and tension with winch. ( may need to secure additional line to tail of halyard to effect. Can also use topping lift if no halyards available. If stay with roller furling on it secure rolling furling gear to bow pulpit or toe rail asap and drop sail if possible.
s/v Hippocampus
Outbound 46, PSC 34
  #7
Old 04-18-2013
We've had two rigging failures over the last 30+ years... one where a spreader root failed, effectively negating the support of an upper shroud (single spreader rig) in about 15-18 knots of breeze. That time the mast folded over neat as you please at the spreader point before we knew what had happened. Fortunately the mast wasn't tall enough to do damage to the deck and we were able to sail home downwind from there.
The second was a lower diagonal rod on a 2 spreader rig, it snapped with bang and the mast had an immediate S in it. Luckily we were able to crash tack (essentially hove to) to get the strain off. We dropped the main, sent someone up to tie a line around the mast at the lower spreader and winched it up to relieve the S and motored home.. in both cases we were on a daysail not far from home.
  #8
Old 04-18-2013
smurphny's Avatar
Over Hill Sailing Club
smurphny is on a distinguished road
You might consider building in some redundancy. I just installed an inner forestay with running backstays that serve as a lower, independent triangular structure. Aside from that, PCP's reply about using spare halyards is the usual first response to a broken shroud or stay. After that, you can always make a quick repair by making an eye with a small compression tool. Having some spare Dyneema onboard is a good idea in order to use lashing to secure stuff. If a mast comes down, it may want to put a hole in the boat but I would think hard before just cutting it free. If you can get it secured, you can use it to jury-rig something to get you home. Carrying spare wire, turnbuckles, swageless ends, a come-along, copper compression sleeves, and sail mending materials may get you home avoiding the need to call for help.
  #9
Old 04-18-2013
jppp is on a distinguished road
Should I assume deck stepped vs keel stepped would make a difference as to when a mast would fail?
'79 Camper & Nicholson 303, Blow'd up labor day
Sunfish just fine
Dyer Dow, crushed in Hurricane Sandy
Angler 204 Cuddy-, Crushed in Hurricane Sandy
Yes all true, No wonder no one will go on the water with me.
  #10
Old 04-18-2013
paradiselostparrot is on a distinguished road
Only so far as the lower end of the mast is more secure and less bending moment as being held at the base and the deck.Above the spreaders would see no difference. In a rollover type dismasting you are more likely to be left with a stub with keel step.A forestay or backstay failure under load I doubt there will be much difference to the damage except again u might see more of a stub.
You may post attachments
You may edit your posts
Stay/Shroud Adjusters sailguy40 Gear & Maintenance 6 01-30-2011 02:49 AM
Damaged Shroud SEMIJim Gear & Maintenance 17 10-01-2007 01:44 AM
shroud tention dodgeboatguy Gear & Maintenance 1 06-26-2007 01:37 AM
shroud clamp.. groundhog Gear & Maintenance 7 05-24-2007 01:24 PM
Shroud tension ktucker8 Gear & Maintenance 31 08-29-2006 09:25 PM
SEO by vBSEO 3.6.1
