Through hulls and hoses - SailNet Community
 3Likes
  • 3 Post By eherlihy
post #1 of 7 Old 04-18-2013 Thread Starter
Gregrosine's Avatar
We've come to agreement on a purchase for our first sailboat! (Yes, congratulations are in order). We are arranging for a survey. I plan on being in attendance at the survey and would like to take the opportunity to label all the hoses and through-hull fittings and sea cocks. At leat it sounds like a good idea. Any suggestions on what I should use to label the fittings and hoses?
Thanks for all the help everyone has given us as we've gone through the boat search process.
Gregrosine is offline
post #2 of 7 Old 04-18-2013
Learning the HARD way...
eherlihy's Avatar
Re: Through hulls and hoses
Definitely be there for the survey.
Do not label any of the through hulls until you own the boat. The survey may yet kill the deal. (sorry, but true)
Draw an outline of the boat on a piece of paper. Sketch in the location of all the through hulls, and type of seacocks (Gate or Ball valve) on the outline.
AFTER the deal closes, make labels with a Brother P-Touch, and place them where they belong.
Faster, chef2sail and downeast450 like this.
eherlihy is offline
post #3 of 7 Old 04-18-2013
sailvayu's Avatar
First off congratulations on the boat. I would suggest you do not bother the surveyor with asking about what each hose does you may distract him from finding other things you need to know about. I would not be concerned about the hoses till you own the boat you may find that the deal will not go through for any number of reasons. you should spend some time with the owner after the check is signed and then ask about things like the hoses.
That said it is a good idea to label stuff. I recommend you get one of those brother label makers. Hoses can sometimes be hard to label. You can use the basic label from the label maker and then wrap some clear packing tape around the hose to help it stay in place long term.
Good luck and I hope it all goes well and you get a good boat.
Capt. Wayne Canning, AMS
sailvayu is offline
post #4 of 7 Old 04-19-2013
Congrats (assuming all goes well with the survey)
Labeling hoses is a great idea. Perhaps not as much for you, as you'll get very used to her, but when you send someone aboard to repair or ask someone to help, you can be sure they will open/close the right seacocks. We leave our main and genset raw water thru hulls closed and they are far enough away that one would have to really crawl around to know what is what, just to do a simple oil change.
I do not think a P-touch labels will last very long in the bilges, unless you figure out how to seal them well. We printed 1"x2" paper labels and spread them out evenly under a piece of heated laminate and sealed them. We cut between the labels with enough laminate to put a hole punch in one end that wouldn't touch the label and expose it. They all get tie wrapped through the hole punch to the hose coming off the seacock.
p.s. yup, we bought a laminator for this. It comes in handy to make checklists for casting off, winterization, instructions for guests on how to use the head, etc.
Jeanneau 54DS
Minnewaska is offline
post #5 of 7 Old 04-19-2013
Bilge-Hamster
divefreak's Avatar
Send a message via Skype™ to divefreak
put the labels not on the vlaves but inside so you can see them when the acces hatches are closed!
Regards René
divefreak is offline
post #6 of 7 Old 04-19-2013
What type of boat is it?
I know the owner's manual for ours has a diagram with all the seacocks and their purpose on it.
Shinook is offline
post #7 of 7 Old 04-24-2013
I have just thought that perhaps using a plastic or polyester tape would be better. Dymo machines are good for this. There is also an industrial series too, those tapes stay put for years.
Dymo Support is offline
Yanmar hoses Greguk Diesel 9 12-17-2012 07:34 PM
New Fuel Hoses jlb40514 Pacific Seacraft 4 01-23-2010 08:38 AM
hoses johnharch Pacific Seacraft 3 11-14-2009 09:36 PM
removing hoses xort Gear & Maintenance 14 06-26-2008 09:08 PM
Choosing Hoses Tom Wood Gear and Maintenance Articles 0 03-27-2002 07:00 PM
