Eye splice in double braid - Page 4 - SailNet Community
 3Likes
post #31 of 33 Old 04-20-2013
pdqaltair's Avatar
Re: Eye splice in double braid
Originally Posted by flyingwelshman View Post
Earlier on pdqaltair made some great arguments against splicing and promoted the bowline.
I just wanted to try the splice. But so far I wouldn't call it 'fun'.
Of course, I was half joking about bowlines; there are often better choices:
* Jib sheets are cow hitched.
* Halyards with... halyard knot.
* The front loops on my jacklines and bridle are spliced. I was bored, I guess.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
Writing full-time since 2014
pdqaltair is offline
post #32 of 33 Old 04-20-2013
I spliced my new VPC halyards and my Sta-Set sheets. Practiced first by splicing line on to all my fenders. One thing that makes it easier to milk in the end of the splice is to POUND THE CRAP out of the thickened line w/ a rubber mallet! Or some large, hard object. Basically get all the fibers to soften and orient themselves in the least twisted up way so the whole mess will slide in to place.
I got two of my VPC core to core splices to bury the cover, the other two I ended up tacking down and wrapping.
AMSTEEL is great and the brummel is easy to do, especially if you use both ends to make the brummel. I'm splicing 1/8" for lazy jacks; a bit tricky b/c it's so thin. What I found works is to pass a splicing wand down the body of the line from the place you want the tail to exit and then butt the piece you want to bury to the end and tape into place. Then just withdraw the wand and VOILA! Pull out the tail, taper and milk it home.
You definitely want to lockstitch AMSTEEL though.
CS 36M DIANTHUS
sailordave is offline
post #33 of 33 Old 04-21-2013
Over Hill Sailing Club
smurphny's Avatar
Another great thing about 12 strand is that any short pieces can be used to make soft shackles. The diamond knot is difficult but worth learning. Also, one helpful thing to do is to go a few inches past the specified final exit point on any of the 12 strand splices so that the tail is assured to pull in. +1 on sewing. It stops any possibility of slippage when NOT under tension.
smurphny is offline
Eye splice in double braid finally davidpm Gear & Maintenance 15 01-07-2011 11:11 AM
Splicing Double Braid BirdBrain333 Pacific Seacraft 3 11-06-2010 12:15 AM
Question About Double-Braid Eye Splice Procedure SEMIJim Seamanship & Navigation 13 12-08-2008 09:38 AM
Anybody ever splice Marlow Braid Quickstep192 Gear & Maintenance 5 05-24-2008 09:24 PM
double braid eye splice dorourke Gear & Maintenance 16 03-19-2008 11:32 PM
