Dousing headsails in breeze when the main is down? - Page 3 - SailNet Community
 10Likes
post #21 of 23 Old 04-22-2013
Tundra Down
downeast450's Avatar
Re: Dousing headsails in breeze when the main is down?
Originally Posted by peterchech View Post
Do you tighten the jib sheets before blowing the halyard and pulling on the down haul? Where on the jib is the down haul attached, halfway up the luff or all the way at the head?
I feel like tightening the sheets as recommended above would recent the jib from coming down though, something about the geometry of a triangle?
Btw I switched from roller furling to hanks shortly after acquiring my boat and have never looked back...
I attach the down haul to a small brass ring I sewed just below the top hank. Not to the head. This allows me to pull down on the head. I tried running the line through the hanks but there is not enough space and it would chafe badly. I sewed rings below each hank. Half inch brass rings I purchased from Sailrite. I adjust the tension on the sheets depending on conditions and am usually controlling the halyard's release as I pull on the down haul. Both lines run to the cockpit. Having the sheet tight places everything securely on the deck.
This set up has made my single handed management of the head sails very simple, convenient and safe.
Down
utchuckd and peterchech like this.
downeast450 is offline
post #22 of 23 Old 04-23-2013 Thread Starter
Down
That's nice! does it interfere with the aerodynamics of the jib though, right along the luff like that?
peterchech is offline
post #23 of 23 Old 04-23-2013
Tundra Down
No, not that I can tell. I am using it with a 135. When it is set, the halyard is tight, I tension the down haul. The flow across the sail looks normal. The leech line works properly. Tell tails normal. The sail looks good. Pointing is good. Helm balance, too. Hull speed is easy. This is also true with a single reef in it. No concerns there. There must be some effect because it is there but I can't see or detect a performance change. If there is an effect it is well worth the convenience. I would think a partially rolled up head sail would be much worse.
Down.
Has anyone sewn a dousing spinnaker sock? patrscoe Gear & Maintenance 2 01-17-2012 09:55 PM
Gaff Rig Main Dousing shazzer333 Learning to Sail 2 11-05-2006 06:22 AM
Difficult Dousing Dilemma blacktie Seamanship & Navigation 17 08-01-2006 12:08 PM
dousing a hanked jib terryny Seamanship & Navigation 17 01-16-2003 05:19 AM
Dousing Sock Hangups bodland General Discussion (sailing related) 2 07-17-2001 04:46 AM
