100 lb of Lead Vs 100 lb of concrete - Page 4 - SailNet Community
 3Likes
post #31 of 36 Old 04-22-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
Re: 100 lb of Lead Vs 100 lb of concrete
right... mass never changes. Even in the Microgravity of earth orbit. You could get a ton of weight moving slowly in orbit by yourself (if you had something to push against or an EVA thruster pack) but it could also crush you very slowly if it trapped you between it and something.
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #32 of 36 Old 04-22-2013
snake charmer, cat herder
zeehag's Avatar
you guys are failing to mention th e lead as a biohazard. will raise your lead levels in blood and cause learning curve disorders--and agression increases.
concrete doesnt do that. is easier to obtain as it isnt a biohazard substance and wil not create learning curve dysfunction.
just add stuff to it as did the taiwanese when they made many boats with concrete keels--they added steel, lead chunks, whatever was in the yard that could be added.
formosa 41, cruising tropics
zeehag is offline
post #33 of 36 Old 04-22-2013
encapsulated in your keel... lead is not going to hurt you. Sanding it, touching raw lead, or cutting it without proper biohazard precautions would bring about lead poisoning.. and that can take years to get over.
Concrete ships are nothing new. The US was playing with them in WW1. There is the remains of one off of Cape May NJ. The Atlantis. It was mothballed after the war and towed to Cape May to make a ferry terminal. Unfortunately it broke loose in a storm before it could be sunk in place and was blown ashore at Cape May Point where it has slowly deteriorated and sunk deeper into the sand.
Almost 100 years after she was launched, there is not a lot left.. but a lot more than if she had been built of steel
Art Haberland
post #34 of 36 Old 04-22-2013
Retired Naval Architect
Explanation of all the above and more at:
Stability of Boats and Ships
Buoyancy is imaginary
Roger Long is offline
post #35 of 36 Old 04-22-2013
Senior Slacker
SlowButSteady's Avatar
Originally Posted by mad_machine View Post
Concrete ships are nothing new. The US was playing with them in WW1. There is the remains of one off of Cape May NJ. ...
There's also one in Capitola, CA (just south of Santa Cruz, CA).
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #36 of 36 Old 04-22-2013
Tundra Down
downeast450's Avatar
I am going to have my next keel cast of gold so it doesn't create a bio hazard. It will be a very small boat!
down
downeast450 is offline
Do Whales like Concrete Boats! Ilenart General Discussion (sailing related) 11 10-10-2010 07:31 PM
Concrete Catch smillinjack General Discussion (sailing related) 9 05-09-2010 03:09 PM
Concrete keels - any facts? kulokoo Sailboat Design and Construction 4 03-22-2010 06:11 PM
Putting cleats on concrete grinfax Gear & Maintenance 18 08-21-2008 09:22 AM
Structural expert's concrete home survived Katrina - Biloxi Sun Herald NewsReader News Feeds 0 04-29-2007 05:15 PM
