Removing painted letters - Page 2 - SailNet Community
 2Likes
post #11 of 24 Old 04-22-2013
HANUMAN
RobGallagher's Avatar
Re: Removing painted letters
I tried it all, oven cleaner, expensive pain remover, scraping, compounding etc.
Light wet sanding took it off in 5 minutes. What a collossell waste of time and money. Lol
downeast450 likes this.
HANUMAN
'88 C&C 30 MKII
NOANK, CT
RobGallagher is offline
post #12 of 24 Old 04-22-2013 Thread Starter
[QUOTE=RobGallagher;1019738]I tried it all, oven cleaner, expensive pain remover, scraping, compounding etc.
Light wet sanding took it off in 5 minutes. What a collossell waste of time and money. Lol[/QUOTE
Well thank you, I will experiment with that a bit. did you have any issues with the surface under the painted on letters?
1977 Bristol 29.9 #17
A slave to the wind
Pegu club is offline
post #13 of 24 Old 04-22-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
easy off works.. but it takes more than 5 minutes... I remember doing that to a truck we had at a place I worked at. I think we would let it sit half an hour at a time
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #14 of 24 Old 04-22-2013
overbored's Avatar
have new vinyl letters made that are slightly wider then the original and cover over the old ones. if it is a different name then sand of the old ones and cover the whole area with a vinyl piece with the name and it will hide the shadow of the old lettering
"GOLD RUSH" PRINDLE 16
overbored is offline
post #15 of 24 Old 04-22-2013
DrB
How to prevent from Running/Drying?
My boat name is on the transom. Putting a slight excess of EASY OFF, to allow it to sit for extend minutes, resulted in the material to slump and run down off the letters. I could soak a rag in it and adhere the rag over the letters, but I am worried with it sitting that long on the gel coat if that is good for the gel coat.
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
post #16 of 24 Old 04-22-2013
chucklesR's Avatar
If the paint has been there for a long period of time the gel coat around it will have oxidized and flaked away at the microscopic level.
What that means is you'll have a 2 millimeter or less 'bump' where the letters where that believe it or not will be visible.
Wet sanding with a long board is the only way to kill it/smooth it off.
chucklesR is offline
post #17 of 24 Old 04-22-2013
Try a heavy cut rubbing compound on a buffer first. If that doesn't get it off then go the wet sanding route. Compounding by hand will probably not do it.
MIsailor is offline
post #18 of 24 Old 04-22-2013
scratchee's Avatar
I may be excommunicated for saying this, but I was in a hurry to remove an old name before re-launching my boat. I used some VERY course sand paper (not sure of the grade, but I'd bet I was the only one in the yard using it above the water line) with plenty of water, and removed the worst of it in a matter of minutes. The vinyl letters had been removed before sanding, but the gelcoat had a very obvious raised edge and discoloration where each letter had been. After sanding, the old letters were virtually invisible unless I stood at just the right angle to the sun, and even then it was just a matter of a different gloss where they had been.
I'm not suggesting a particular method as much as I'm saying that sometimes you just have to pick something that's effective and get it done, unless you're trying to win a boat show or something.
scratchee is offline
post #19 of 24 Old 04-22-2013
Senior Moment Member
SloopJonB's Avatar
Oven cleaner (Easy Off) works extremely well, but only on sign paint. Other types of paint require strippers appropriate to themselves.
If it isn't sign paint, I suspect sanding & buffing would be the fastest & easiest.
SloopJonB is offline
post #20 of 24 Old 04-23-2013
Tundra Down
downeast450's Avatar
Rob is right on! A da sander with 220. then 320, then up to 600 wet or dry hand sanded wet, then 3M finessit II using a power buffer. The buffer must be one that is limited to under 2000 rpm to keep things from getting too hot. The only risk is it will look better than the rest of the transom so do the whole thing. I just did this to a rolled on coat of high solids, 2 part urethane yesterday and it shines. I started with 150 because the surface was rough to begin with. Sanding is good! Go slowly with the coarse (220) grit!
Down
downeast450 is offline
removing painted numbers from inflatable anemoneii Gear & Maintenance 9 03-25-2010 09:54 PM
removing old letters Julie303 Gear & Maintenance 6 05-19-2007 11:53 PM
Fwd: letters to the Boston Globe NewsReader Mass Bay Sailors 0 08-07-2006 10:15 AM
removing painted boat name maureena5 Gear & Maintenance 1 02-20-2001 07:08 AM
