Proper alignment = Quiet - SailNet Community
 3Likes
post #1 of 13 Old 04-23-2013 Thread Starter
T37Chef's Avatar
Smile Proper alignment = Quiet
With the new engine installed and aligned I am amazed at the difference it makes inside the boat. The Sundown Heat & Sound barrier has also provided some additional noise reduction as well as a covered intake but its evident that a precise alignment makes all the difference. Some things are worth the time, I urge you to be sure your alignment is right, for other reasons than just noise of course...but wow. Partial credit goes to Beta and their custom mounts which were so well engineered. Most of the credit goes to the mechanic
JimMcGee, zeehag and jimgo like this.
Shawn
T37Chef is offline
post #2 of 13 Old 04-23-2013
Re: Proper alignment = Quiet
I'd have to second that regarding the alignment. We only had the hunter out a couple of times last season then had the motor mounts replaced along with some other eng work we were having done. the difference is like night and day as it is now and the mech wanted to tweak it a bit. It's like a new engine and was well worth the $$$
UncleJim is offline
post #3 of 13 Old 04-23-2013
Asleep at the wheel
jimgo's Avatar
Where did you have the work done?
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #4 of 13 Old 04-24-2013
chef2sail's Avatar
I will third that. We had our new, engine mounts a new shaft, cutlass bearing, dripless PSS shaft installed at Haven Harbor where your boat is Jim.
Quieter and smoother for sure
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #5 of 13 Old 04-24-2013
Windseeker
Problem I have with a quiet motor is I can't tell if its on.
theonecalledtom is offline
post #6 of 13 Old 04-24-2013
trantor12020's Avatar
Appreciate insight in doing alignment yourselves. I have to redo mine. Didn't have the stamina to do a good job last time.
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
trantor12020 is offline
post #7 of 13 Old 04-24-2013
snake charmer, cat herder
zeehag's Avatar
looking forward to a quieter engine after a good re alignment--also will again address packing gland, as it is having way too much fun as a dysfunctional.....
formosa 41, cruising tropics
zeehag is offline
post #8 of 13 Old 04-24-2013
JimMcGee's Avatar
Don't underestimate the difference new motor mounts can make. When I did ours I was amazed at how much quieter the motor was.
And the PSS shaft seal - after having one I'd never go back.
Chef, I'm curious about the Sundown Heat & Sound barrier. Can you tell us a little more about it?
Thanks,
Jim
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
post #9 of 13 Old 04-24-2013
It's quite amazing how much of the 'engine noise' most of us suffer is actually from non-engine related vibration. Cabinet doors, stove grills, companionway ladders all contribute to an overall noise level that often isn't differentiated from actual noise of the motor, which is for the most part a pretty low frequency rumble.
We've gone around and put soft pads under all our storage cabinet doors, and even the mating parts of the engine box for a significant reduction in noise under power.
For actual engine noise, one of the neatest and most effective tricks is to drape the engine block with a dentist's Xray blanket - be careful not to block the air intake..
Faster is offline
post #10 of 13 Old 04-24-2013
Asleep at the wheel
jimgo's Avatar
Faster, doesn't that increase the engine temperature? I could see lining the walls with it, but putting a blanket over the engine seems somewhat counterproductive.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
Quiet in here..... scottbr Lake Huron 18 01-03-2011 12:35 PM
alignment cutterorient Gear & Maintenance 9 03-16-2010 11:51 PM
Proper shaft alignment Joshua Dawn Gear & Maintenance 20 12-13-2009 04:17 PM
Diesel alignment Waltthesalt Diesel 2 09-24-2009 02:01 PM
engine alignment obiec Gear & Maintenance 1 04-20-2003 08:20 AM
