Small Boat Jack Lines and Safety Tethers - SailNet Community
 1Likes
  • 1 Post By RichH
post #1 of 3 Old 04-24-2013 Thread Starter
Sparrow Girl
sparrow16's Avatar
Hi all,
I plan on cruising the San Juan's with my local sailing club this summer, where I would be sailing single-handed on my Sparrow 16. (for info on the Sparrow, check out Sailboatdata.com) In preparation for this I have been looking into safety tether systems for my boat.
My cockpit is only about 6' to 7' long and the beam of my boat is 6.5'. As such I realized that the standard 2 m/6' tether could not work for me as if I were to go over the side, I'd be suspended next to the side of the hull not able to get back on board. (The Sparrow has a pretty high freeboard compared to many boats her size.)
The solution I've come up with so far is to use a short jackline on the floor of the cockpit and a short (~1m) safety tether attached to the jackline. With this I would have full freedom to move fore and aft in my cockpit without having to have a longer tether that could allow me to dangle over the side of the boat.
I have a couple questions:
1) Does this solution sound reasonable for a small cruising sailboat like mine?
2a) If your answer to question 1 is negative, what would you recommend?
2b) If your answer to question 2 is positive, where can find a shorter (1m) long tether to purchase? (Or,is this something I could have my sailmaker make for me?)
Thanks!
Christine
sparrow16 is offline
post #2 of 3 Old 04-24-2013
RichH's Avatar
Re: Small Boat Jack Lines and Safety Tethers
VERY reasonable.
Your tether should the short enough to keep you on board.
You may also want a tether that has two possible terminal connections on the same tether ... one for 'long' and the other for 'short'.
Any sailmaker or anyone with an 'industrial' sewing machine with strong polyester or Tenara (PTFE) thread can do this for you.
Also to consider ... a tether end connection that is EASILY releasable under load, as small boats do sometimes become 'upside down' and when they do you MUST be able to open that connection easily ... and do so faster than how long you can hold your breath. (A worst case scenario, of course). ;-)
msmith10 likes this.
RichH is online now
post #3 of 3 Old 04-24-2013
Barquito
Barquito's Avatar
With the necessity of having a really short tether, I wonder if you could get away with just having fixed attachment points in the cockpit. Cool looking boat, btw. Post pictures when after your trip!
Valiant 32
Barquito is online now
Jack lines and tethers rjcaudle Seamanship & Navigation 61 12-29-2011 05:17 AM
Safety Harnesses and Tethers John Rousmaniere Learning to Sail Articles 0 05-06-1999 08:00 PM
Safety Harnesses and Tethers John Rousmaniere Seamanship Articles 0 05-06-1999 08:00 PM
Safety Harnesses and Tethers John Rousmaniere Gear and Maintenance Articles 0 05-06-1999 08:00 PM
Safety Harnesses and Tethers John Rousmaniere Cruising Articles 0 05-06-1999 08:00 PM
