centerboard day sailer: raising/lowering sails in stronger winds - Page 2 - SailNet Community
 1Likes
post #11 of 19 Old 05-03-2013 Thread Starter
CaribDream's Avatar
I appreciate all of this. One question still remains though - if I am attempting to launch with the wind fully astern - having the sheets free doesn't help me in this situation as the boom is blown all the way out until it's against the shroud and the main fills with air?
I agree that sailing without motor is teaching me a lot. However, I want to sail on the Sound in CT and the 2 launch points that are accessible to me have long channels (4 miles in one case) to get to sailing grounds. I have been told authorities "frown heavily" on tacking in the channel. 4 miles is a long way to paddle if the wind is not right or dies completely.
In order to keep my wife interested, I need to make things as comfortable as possible. Tossing her in the drink a few times with capsizes or making her paddle for miles isn't going to help my cause It would seem that the motor can make some tricky things a little less tricky, and dead wind times a little easier.
Go sailing now my brother,
It's later than you think.
CaribDream is offline
post #12 of 19 Old 05-03-2013
krisscross's Avatar
Re: centerboard day sailer: raising/lowering sails in stronger winds
You need to turn your boat around, so that it is facing the wind.
Keep it on a rope loop so that it does not drift away from the pier. Then, when all the sails are up and you all are ready, let go the rope end, hold the boom with one hand so that the main catches wind and turns the boat around, hold the tiller in the other hand, sheet in, and you are sailing.
Plato
krisscross is offline
post #13 of 19 Old 05-03-2013
krisscross's Avatar
Yes, in that case a small motor is pretty much a must have.
Plato
post #14 of 19 Old 05-03-2013 Thread Starter
CaribDream's Avatar
[quote=krisscross:1025066]
Must be another married man to understand my plight
I have a buddy that busts my chops about motors. But the way I see it - I'm lucky that my wife wants to sail - and she is looking forward to all of our upcoming ASA training. She just doesn't want to be on the hairy edge. She'll never be the one wanting to dip a rail or hike out over a rail struggling to keep a daysailer upright. I can definitely live with that vs a wife that doesn't want to sail with me at all.
post #15 of 19 Old 05-03-2013
krisscross's Avatar
No, dude... I was thinking about the need to paddle your boat for 4 miles...
When I was married, sailing was my chance to have some quality R&R alone...
Plato
post #16 of 19 Old 05-03-2013
I agree with kriskross - to clarify - rig with bow to wind, sheets loose. When you push off, sheet in (you should still be in irons) tight, then either back wind the jib or hold the boom out a bit, the boat will turn and then you're sailing. If you don't sheet in tight b4 this, a wild gybe is possible, which is no way to start your day.
4 miles? That's a long way even with a motor, even for a larger boat with an inboard. I might consider a different launch or body of water.
FlyingJunior is offline
post #17 of 19 Old 05-03-2013 Thread Starter
CaribDream's Avatar
Welcome to Connecticut... 4 mikes is the extreme of the two places useful to me. One of the hardest things in CT is not only finding a public launch, but also finding a launch with parking available. Lame
On most wind directions, I should be able to sail a good portion of the channel - it's a dogleg so one of the legs should be sailable with wind.
My other option is motoring a much more direct path through shallow water. Plenty of water for a small motor, but not nearly enough for putting the centerboard down to sail. Yet another reason I got a motor to supplement sail.
post #18 of 19 Old 05-03-2013
krisscross's Avatar
If you are going more or less downwind through shallow water you do not need to lower the CB. Pull it up all the way.
Plato
post #19 of 19 Old 05-03-2013
Barquito
Barquito's Avatar
True if he still has enough depth for the rudder.
Speaking of rudders. Learn to scull the boat with the rudder. It can be handy for getting that last few feet to the dock, or turning the boat out of irons, etc. When the wind totally died, I have sculled my Catalina 22 a half mile back to my mooring pin. You need the CB down to scull.
Valiant 32
Barquito is offline
raising swinging centerboard Paddler76 Gear & Maintenance 1 05-07-2011 06:58 AM
Tips on lowering sails sailguy40 Learning to Sail 18 06-16-2010 12:18 PM
Centerboard raising mechanism... deryk Morgan 4 06-08-2008 07:50 PM
Sailing in stronger winds Rshanks Learning to Sail 45 01-21-2008 01:39 PM
mast raising and lowering divicolouis Gear & Maintenance 5 08-08-2003 10:08 PM
