Freshwater Flush Tank - SailNet Community
post #1 of 2 Old 04-25-2013 Thread Starter
It appears that we will soon be designated a "no discharge" zone, including galley waste. I'm thinking that I will have three through hull fittings that will almost never be used and probably never have to be used. So I am thinking that I should remove them (Head outlet, galley sink outlet and lavatory outlet) and glass over the holes. If I add a freshwater flush tank I could then remove four through hulls. So my questions are:
How to size the flush water tank. What percent of the holding tank should the flush tank be?
Should I use galley and lavatory waste as flush water. That way the flush tank could serve as holding tank for the sinks.
Is there any danger associated with glassing over old through hull openings? Assuming competent work.
Thanks,
John
ccriders is offline
post #2 of 2 Old 04-25-2013
krisscross's Avatar
Re: Freshwater Flush Tank
If you have good seacocks on them maybe you can just close them and leave things as they are in case you want to sell your boat at some time.
krisscross is online now
Freshwater System Flush BGS Gear & Maintenance 3 08-12-2012 03:34 PM
Convert existing steel freshwater tank to blackwater holding tank? patrickstickler General Discussion (sailing related) 7 09-24-2010 07:55 PM
freshwater tank leaking under v berth jbrockpiano Gear & Maintenance 4 03-13-2010 10:50 AM
Flush Seacocks Aleutian Tern Racing 6 12-21-2008 05:35 AM
Ethylene glycol in my freshwater tank derekt Gear & Maintenance 0 04-27-2005 07:43 AM
