I Need Ideas - Page 2 - SailNet Community
 13Likes
post #11 of 57 Old 04-25-2013
krisscross's Avatar
Re: I Need Ideas
Originally Posted by knothead View Post
Thanks. I think an arch might be the way to go, but I'm not sure where. I obviously has to be behind the boom, but I'm thinking that it is going to have to be behind the backstay too. Or just forward of it following the same angle. I suppose it will have to be high enough to be able to pass under it comfortably. Or maybe low enough to be able to put the traveler on top with the solar panels straddling the backstay aft of the traveler. ????
I would pass the backstay through the arch (free floating through an opening that is big enough to avoid any chafe) and mount the traveler on the lead edge of it. If you place the arch too far aft you will have a hard time supporting /connecting with the boat.
Nor'sea 27 is my dream boat. I just don't have the coin for it.
krisscross is offline
post #12 of 57 Old 04-25-2013
Re: I Need Ideas
Just some ideas. Two separate backstays for installation of wind,solar, flexible solar panels over hatches, rigid solar panels as bimini and base for radar, wind gen. (all with storm conditions in mind). Adjustable, reef-able solar wings on side(s) of boat or wherever you locate.
....Contact M.I.T or other universities and research groups, including solar aircraft experiments. It might be a fun project for them if you can get access to them.
sidney777 is offline
post #13 of 57 Old 04-25-2013 Thread Starter
Re: I Need Ideas
Interesting ideas. I don't think I could get a bimini to work under the low boom, but I like the idea of the flexible panels. Thanks.
I agree, mounting everything securely is the biggest concern. That's why I'm thinking that I might want to design everything together. Radar mast, arch, traveler, wind vane panel supports etc. Maybe even that stern rail that I've always wanted.
knothead is offline
post #14 of 57 Old 04-25-2013
Re: I Need Ideas
What's your objection to the radar on the mast? It's a good place for it, and would simplify things considerably...
Add a stern rail, and a solid rail replacing the lifelines surrounding the cockpit... Mount the solar panels on those rails, able to articulate with the changing angle of the sun, and stowed vertically for sailing/heavier weather...
Or, make them portable, able to be stowed below when not in use... That's the setup I use, mine simply mount on articulating poles that sit in a pair of fishing rod holders on my stern rail... Really nice to be able to stow them when not in use...
Then, you'd only need a single pole for a wind generator... Or, you could consider a wind gen suspended in the rig, although that only works at anchor, of course...
Putting a stern arch on such a pretty boat would be criminal, in my opinion... (grin) And all that crap on the back is only gonna interfere with your windvane, anyway...
JonEisberg is offline
post #15 of 57 Old 04-25-2013
krisscross's Avatar
Re: I Need Ideas
That makes sense. I would make sure you can have a safe way of working with all that gear in bad weather - a stern rail would help for sure.
The radar mast could provide additional stability and rigidity to the arch (third leg, so to speak. I might also incorporate stubs leading aft to allow for a potential windvane installation later.
post #16 of 57 Old 04-25-2013
Skipper Jer's Avatar
Re: I Need Ideas
A slight adjustment to the course of the thread if I may.
To Jon Eisberg: What size are those panels and do they provide all the power you need?
I like the idea of pointing the panels as required and that they can be stowed below when not needed.
knothead likes this.
Nor'sea 27
And the trees are all keep equal by hatchet, axe and saw...RUSH
I invented a new word today, plagiarism.
Skipper Jer is offline
post #17 of 57 Old 04-25-2013
Tundra Down
downeast450's Avatar
Re: I Need Ideas
Jon,
I like your solar panel solution, Are there any details you would share?
Down
Islander-28, Marshall Sandpiper
downeast450 is offline
post #18 of 57 Old 04-25-2013 Thread Starter
Re: I Need Ideas
I can't disagree about the criminal thing. That's why I'm really intent on thinking this out thoroughly before I make any big decisions.
The main problem with the radar on the spar is that it's set up to tabernacle and trailer. I probably won't be doing that much though so it is a possibility. It is sounding like a lot of stuff on the back of that little boat.
I was just thinking that if I could come up with something that incorporates everything in one neat, (ie, not too ugly), set-up, it might be the way to go. But maybe not. That's why I'm throwing it out there for consideration.
I really like your solar panel setup. I guess I really need to think about what kind of panels and how many I am going to need before I get too far into this.
Exactly. Great idea. That's why I'm thinking that I should try to figure out all the details ahead of time.
Thanks everyone for the input. It really helps.
What I'm going to try to do is find someone that can actually draw or use a computer drawing program (I can't), and have them try to illustrate the ideas that you all are coming up with.
I did sign up to visit the yahoo site and am currently awaiting approval. You're right Caleb. pita)
I am curious to see how or if others have addressed this issue of too much cool stuff and too small a boat to put it on.
knothead is offline
post #19 of 57 Old 04-25-2013
Daniel - Norsea 27
Rhapsody-NS27's Avatar
Re: I Need Ideas
Nice Boat!
Get on the Yahoo Group. Very good support group for Nor'sea owners. I have the rare aft-cockpit.
There are some pictures of other boats in the group. The radar on mine is mounted on top of a pole on the stern rail. I'm looking at possibilities for solar or wind in the future, along with other projects. I'm trying to document my work on my blog (see signature below).
The pictures on the Yahoo group can be helpful for ideas. See if you can find pictures of the Nor'sea 27, Daphne. It's been sold to someone else but the previous owner, Teresa, still has pictures floating around somewhere online. Try looking at her current site, Sailing Simplicity, I'm sure there's still info about Daphne there. Her husband, Ben, also used to have a Nor'sea 27 and owned a BCC after that. Teresa had a simple arch with Solar and a wind vane. Again, more ideas. Even with this simple arch, it still looked pretty good.
Of course, the guys at the Yahoo group do like seeing "boat porn" of other Nor'seas so you can post some more pictures there too.
I've had my boat for a year and learning a lot about it. I enjoy seeing what others have done to their boats. Let me know if there's anything else I may be able to help with.
knothead and Skipper Jer like this.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is offline
post #20 of 57 Old 04-25-2013
Daniel - Norsea 27
Re: I Need Ideas
It's worth it.
I expected to spend around $15k for my first boat but mine came available and spent just over twice that amount. I'm still happy with it.
Daniel
1981 Nor'sea 27,
-Paul Carvel
Ideas frozenkim Cruising and Sailing with Children 20 09-28-2015 06:31 PM
Solent Stay Ideas-Possible hairbrained ideas Joel H. General Discussion (sailing related) 39 01-26-2013 08:09 PM
Any Ideas justified General Discussion (sailing related) 25 10-03-2012 01:33 PM
Any ideas? PaulSims C22 7 06-30-2012 01:40 PM
